port mirroring on 3845 cisco router
olakunle06
Hi everyone,
please i want to configure port mirror on a port on this router,i have searched all the documentation to no avail pls can anyone help with the exact commands to achieve this task.i appreciate ur quick response.thanks a lot
satish_zanjurne
Level 4
Level 4
SUMMARY STEPS
1. enable
2. configure terminal
3. ip traffic-export profile profile-name
4. interface interface-name
5. bidirectional
6. mac-address H.H.H
7. incoming {access-list {standard | extended | named} | sample one-in-every packet-number}
8. outgoing {access-list {standard | extended | named} | sample one-in-every packet-number}
9. exit
10. interface type number
11. ip traffic-export apply profile-name
Refer the below link..
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gt_rawip.html
HTH...
hi Guys,
does anyone knows where i can find in the DOC CD 12.4 the ip traffic-export commands etc...
Cisco now changed the DOC CD of the security part, the ip traffic-export used to be under
Secure Infrastructure
IP Traffic Export
do you any idea how i can access it now.
Hello Samer,
http://www.cisco.com/en/US/docs/ios/security/command/reference/sec_book.html
from www.cisco.com select quick links-> documentation -> IOS and you will find command references and command guides
Hope to help
Giuseppe
