Port mirroring on a 4507
Shannon Sutter
I'm trying to mirror traffic from one port on the switch to another one.
What i'm doing so far is the following:
monitor session 1 source interface Gi3/1
monitor session 1 destination interface Gi3/29
But the problem is that Line Protocol is down on por 29.
I've been reading a little and looks like i need to add the commands "ingress vlan"
I tried this and port 29 still says line protocol down. Am i missing something?
Zeek
hennigan
It sounds like a physical layer problem. Have you verified the NIC and cables of the sniffer? If you plug the same sniffer and cable into a different port than Gi3/29, does that port come up?
merryllem
Does it looking something like this
GigabitEthernet3/29 is up, line protocol is down (monitoring)
My bad.
I was adding the wrong Vlan #.
After i added the right vlan it fired right up.
Thank you,
zeek
