Port monitoring issue
tarunavakonar
I want to configure port monitoring between two ports on cisco 4506.but its not working.
configuration:
monitor session 1 source interface gi3/16
monitor session 1 destination interface gi3/16
sh monitor:
Session 1
Type : Local Session
Source Ports :
Both : Gi3/16
Destination Ports : Gi3/4
Plz reply on urgent
hasnain321
Tarun,
It is just two step process that you have written. Double check your configuration your source and destination are same in config.
no this is by misprinting
u can show the output
then your configuration is right. If it is not working you should check other things at system level.
Configuration for this is straight forward.
