Port security: Migrating from a Cisco WS-C3548-XL to a Cisco WS-C3850-48P
Supercell292929
  Yeah, huge leap in switches! Looong overdue! This previous public switch had the following on all its ports. These commands do not transfer to the 3850. Any idea how to get this kind of security put into play on the 3850's?
Thank you in advance.
port security
port security max-mac-count 5
port security action shutdown
port security aging time 2
port storm-control broadcast action filter
port storm-control broadcast trap
port storm-control broadcast threshold rising 250 falling 150
port storm-control multicast action filter
port storm-control multicast trap
port storm-control multicast threshold rising 250 falling 150
port storm-control unicast action filter
port storm-control unicast trap
port storm-control unicast threshold rising 3000 falling 1000
###### WHEN MIGRATED TO NEW SWITCH:
xxxxx(config-if-range)# port security
% Invalid input detected at '^' marker.
xxxxx(config-if-range)# port security max-mac-count 5
xxxxx(config-if-range)# port security action shutdown
xxxxx(config-if-range)# port security aging time 2
xxxxx(config-if-range)# port storm-control broadcast action filter
xxxxxconfig-if-range)# port storm-control broadcast trap
xxxxx(config-if-range)# port storm-control broadcast threshold rising 250 falling 150
xxxxx(config-if-range)# port storm-control multicast action filter
xxxxx(config-if-range)# port storm-control multicast trap
xxxxx(config-if-range)# port storm-control multicast threshold rising 250 falling 150
xxxxx(config-if-range)# port storm-control unicast action filter
xxxxx(config-if-range)# port storm-control unicast trap
xxxxx(config-if-range)# port storm-control unicast threshold rising 3000 falling 1000
Francesco Molino
here a translation:
port security --> switchport port-security
port security max-mac-count 5 --> switchport port-security maximum 5
port security action shutdown --> switchport port-security violation shutdown
port security aging time 2 --> switchport port-security aging time 2
port storm-control broadcast action filter --> switchport port-security
port storm-control broadcast trap --> storm-control action trap
port storm-control broadcast threshold rising 250 falling 150 --> storm-control broadcast level pps 250 150 (Now you can set storm in pps, bps and on your old switch it was pps per default basis if I remember good)
port storm-control multicast trap --> already enabled with "storm-control action trap"
port storm-control multicast threshold rising 250 falling 150 --> storm-control multicast level pps 250 150
port storm-control unicast trap --> already enabled with "storm-control action trap"
port storm-control unicast threshold rising 3000 falling 1000 --> storm-control unicast level pps 3000 1000
PS: Please don't forget to rate and mark as correct answer if this answered your question
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Francesco Molino
here a translation:
Francesco
xxxxxx(config-if)#switchport port-security
Command rejected: GigabitEthernet2/0/1 is a dynamic port.
Ah, got it.
Needed to add the following: switchport mode access
Thank you!
