Port up/up but no mac-address on interface
palmerr21
Has anyone ever seen a network cable be the cause of a layer 2 issue when your interface on your switch is UP/UP, no input errors
you have outgoing packets however no input packets from the server? From my experience when your you're interface is up/up and
clean and you see no incoming packets your looking at an server issue - may it be nic / config or other issue.
I guess you can have an issue if you pins on your jack get bent/crossed but I would assume you would see errors.
BTW -- Server is an ELM 6000 McAfee Security  Manager
Your thoughts!
Mark Malone
stick a laptop on the port rule out the server as being the issue , if laptop works fine you prob have a server issues somewhere , nics broadcast the mac so i wouldn't say its the cable
