02-02-2020 08:22 PM
Hi all,
Just wondering if this is possible on cisco.. doesn't seem to have worked for me.
I am trying to do some Portforwading with the same Port number to the same router on 2 different WAN interfaces.
ip nat inside source static tcp 192.168.0.252 50000 interface Cellular0 50000
ip nat inside source static tcp 192.168.0.252 50000 interface Dialler2 50000 ==> not working, as cisco does not allow me to have 2 similar port numbers. So I can only have one of the above, not both. However, I would need both working as this is a failover config.
Thanks so much all.
Solved! Go to Solution.
02-04-2020 03:25 PM - edited 02-04-2020 03:26 PM
Hello
@nwekechampion wrote:
Hi Paul,
I tried the "extenable" at the end of the nat statement but the router IOS would not recognize that command. Could I be missing something here please?
The reason being is your specifying a physical interface instead of a nexthop ip address.
ip nat inside source static tcp 192.168.0.252 50000 <nexthop ip x.x.x.x> 50000 extendable
02-05-2020 10:57 PM
Thanks Paul,
That worked, Config I mean, but then I get the message below:
*Feb 6 05:46:47.862: %IP-4-DUPADDR: Duplicate address 110.60.65.2 on GigabitEthernet0/2, sourced by 0c71.2e7f.ad02
FYI, I replicated it on a lab environment first, hence the interfaces are different:
ip nat inside source route-map WAN01 interface GigabitEthernet0/1 overload
ip nat inside source route-map WAN02 interface GigabitEthernet0/2 overload
ip nat inside source static tcp 192.168.1.2 80 110.60.65.2 80 extendable
ip nat inside source static tcp 192.168.1.2 80 200.60.65.2 80 extendable
02-03-2020 02:16 AM
this is not Cisco specific, you pose a requirement that may not be possible with any vendor.
Maybe you can take a different view at your requirement
- first do the nat !
- then make this NATted traffic routable using two different paths
I guess this will not be able using the interface address of the two links, you need an additional public address ,
that must also be reachable on both WAN links, so also need something lik BGP to publish both routes to this address.
02-04-2020 02:14 PM
02-03-2020 02:18 AM - edited 02-03-2020 02:25 AM
Hello
Add extenable keyword to the static nat statements and it should then allow you.
ip nat inside source static tcp 192.168.0.252 50000 interface Cellular0 50000 extenable
ip nat inside source static tcp 192.168.0.252 50000 interface Dialler2 50000 extenable
02-04-2020 02:11 PM
Hi Paul,
I tried the "extenable" at the end of the nat statement but the router IOS would not recognise that command. Could I be missing something here please?
Thanks so much for your reply earlier
Hello
Hi Paul,
02-05-2020 10:57 PM
Thanks Paul,
02-11-2020 03:43 PM - edited 02-11-2020 03:47 PM
02-06-2020 09:05 PM
02-07-2020 03:51 AM
02-03-2020 02:32 AM
a workaround would be to use an EEM script that adds/removes the static NAT entry based on which interface is active. This would look something like below:
track 1 ip sla 1 reachability
interface Cellular 0
description Primary_Link
interface Dialer 2
description Backup_Link
ip sla 1
icmp-echo 8.8.8.8 source-interface Cellular 0
frequency 3
ip sla schedule 1 start-time now life forever
ip route 0.0.0.0 0.0.0.0 Cellular 0 track 1
ip route 0.0.0.0 0.0.0.0 Dialer 2 254
ip nat inside source static tcp 192.168.0.252 50000 interface Cellular 0 50000
event manager applet PRIMARY_ISP_DOWN
event track 1 state down
action 1.0 cli command "enable"
action 2.0 cli command "no ip nat inside source static tcp 192.168.0.252 50000 interface Cellular 0 50000"
action 3.0 cli command "ip nat inside source static tcp 192.168.0.252 50000 interface Dialer 2 50000"
action 4.0 cli command "end"
event manager applet PRIMARY_ISP_UP
event track 1 state up
action 2.0 cli command "no ip nat inside source static tcp 192.168.0.252 50000 interface Dialer 2 50000"
action 3.0 cli command "ip nat inside source static tcp 192.168.0.252 50000 interface Cellular 0 50000"
02-04-2020 02:12 PM
02-07-2020 02:48 AM
actually, I think the below might work as well:
ip nat inside source list 101 interface Cellular0 overload
ip nat inside source list 102 interface Dialer2 overload
access-list 101 permit tcp host 192.168.0.252 any eq 50000
access-list 102 permit tcp host 192.168.0.252 any eq 50000
02-11-2020 08:59 AM
02-11-2020 09:02 AM
