05-04-2009 10:45 AM - edited 03-04-2019 04:37 AM
can it provide dynamic addressing ie DHCP?
Smart serial ports are new serial connectors that replace 2 DB-60s or serial i/fs per WIC.....I cant understand this....am I correct...could you explain?
05-04-2009 11:44 AM
Hello Baljit,
I can answer for the first part
PPP can provide dynamic ip address using IPCP negotiation that is part of the PPP protocols.
Hope to help
Giuseppe
05-09-2009 04:05 AM
hi giuseppe,
Can you explain about IPCP negotiation (in PPP)and its similarities & differences to DHCP in DYNAMIC IP ADDRESSING?
What is the mechanism of IPCP?
thnx baljit
05-09-2009 04:23 AM
Hello Baljit,
you can find here all the details about IPCP
http://www.faqs.org/rfcs/rfc1332.html
IPCP can assign an ip address taken from a pool like DHCP.
DHCP can assign always the same ip address to a specific MAC address (reservation).
IPCP can receive the ip address conditioned on the authentication phase that identify the user.
IPCP scalability is achieved by using external AAA servers (typically RADIUS) instead of storing username /pwd pairs on the local device.
the mechanism is quite simple with the two parts that exchange IPCP frames in order to reach an agreement on what ip addresses to use on the PPP link.
The client side accepts the server proposal and can install a default route.
Hope to help
Giuseppe
