PPP CHAP Authentication Problem
Roopak Sethi
Visitor
I  am trying to implement PPP chap Authentication on two routers connected  via serial interfaces. I just want to know which router will call which  router and which router will challenge which router.
But according to following link of cisco
http://www.cisco.com/en/US/tech/tk713/tk507/technologies_configuration_example09186a0080094333.shtml
It  is wriiten that If Router 1 Initiates a call to Router 2, Router 2  would challenge Router 1, but Router 1 would not challenge Router 2. This occurs because the PPP authentication chap callin command is configured on Router 1.
So, according to cisco document Router 2 should challenge Router 1. But how in my case Router 1 is challenging Router 2 ???
This is confusing me.. Please help
The configurations are as follows:-
r1---serial link... r2
R1:-
username R2 password 0 12345
interface Serial1/0
ip address 10.10.10.1 255.255.255.252
encapsulation ppp
serial restart-delay 0
no dce-terminal-timing-enable
ppp authentication chap callin
R2:-
username R1 password 0 12345
interface Serial1/0
ip address 10.10.10.2 255.255.255.252
encapsulation ppp
https://learningnetwork.cisco.com/thread/33576
Regards.
Alain
6 Replies 6
cadet alain
post your debug output.
Regards.
Alain
Hi Sir,
Following is the debug output:-
>>>>>R1<<<<<<
R1(config-if)#
*Oct  5 13:12:30.227: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
R1(config-if)#
*Oct  5 13:13:16.387: Se1/0 PPP: Authorization required
*Oct  5 13:13:16.395: Se1/0 CHAP: O CHALLENGE id 2 len 23 from "R1"
*Oct  5 13:13:16.479: Se1/0 CHAP: I RESPONSE id 2 len 23 from "R2"
*Oct  5 13:13:16.483: Se1/0 PPP: Sent CHAP LOGIN Request
*Oct  5 13:13:16.491: Se1/0 PPP: Received LOGIN Response PASS
*Oct  5 13:13:16.495: Se1/0 PPP: Sent LCP AUTHOR Request
*Oct  5 13:13:16.495: Se1/0 PPP: Sent IPCP AUTHOR Request
*Oct  5 13:13:16.503: Se1/0 LCP: Received AAA AUTHOR Response PASS
*Oct  5 13:13:16.503: Se1/0 IPCP: Received AAA AUTHOR Response PASS
*Oct  5 13:13:16.503: Se1/0 CHAP: O SUCCESS id 2 len 4
*Oct  5 13:13:16.507: Se1/0 PPP: Sent CDPCP AUTHOR Request
R1(config-if)#
*Oct  5 13:13:16.515: Se1/0 CDPCP: Received AAA AUTHOR Response PASS
*Oct  5 13:13:16.543: Se1/0 PPP: Sent IPCP AUTHOR Request
>>>>>R2<<<<<<
R2(config-if)#no shut
R2(config-if)#shut
R2(config-if)#
*Oct  5 13:13:10.595: %LINK-5-CHANGED: Interface Serial1/0, changed state to administratively down
R2(config-if)#
R2(config-if)#
*Oct  5 13:13:10.595: %ENTITY_ALARM-6-INFO: ASSERT INFO Se1/0 Physical Port Administrative State Down
*Oct  5 13:13:11.595: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to down
R2(config-if)#
*Oct  5 13:13:15.631: %LINK-3-UPDOWN: Interface Serial1/0, changed state to up
*Oct  5 13:13:15.631: %ENTITY_ALARM-6-INFO: CLEAR INFO Se1/0 Physical Port Administrative State Down
R2(config-if)#
*Oct  5 13:13:15.635: Se1/0 PPP: Using default call direction
*Oct  5 13:13:15.639: Se1/0 PPP: Treating connection as a dedicated line
*Oct  5 13:13:15.639: Se1/0 PPP: Session handle[D5000002] Session id[2]
*Oct  5 13:13:15.639: Se1/0 PPP: Authorization required
*Oct  5 13:13:15.703: Se1/0 PPP: No authorization without authentication
*Oct  5 13:13:15.735: Se1/0 CHAP: I CHALLENGE id 2 len 23 from "R1"
*Oct  5 13:13:15.739: Se1/0 CHAP: Using hostname from unknown source
*Oct  5 13:13:15.739: Se1/0 CHAP: Using password from AAA
*Oct  5 13:13:15.739: Se1/0 CHAP: O RESPONSE id 2 len 23 from "R2"
*Oct  5 13:13:15.795: Se1/0 CHAP: I SUCCESS id 2 len 4
R2(config-if)#
*Oct  5 13:13:16.795: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial1/0, changed state to up
Regards.
Alain
Hi Sir,
It means the router with "PPP authentication chap callin" command  will raise the challenge..
But what about the cisco document ??? Is it wrong.??
sometimes Cisco docs have some wrong infos or the info is outdated or not pertaining to some cases or simply badly worded.But I can't say which case this is here.
I think that what counts is the real operation you observe when labbing.
Regards.
Alain
I got my answer
Thanks Sir...
