PPP Multilink configuration
sudan_023
Hello Guys,
I have configured my two vdsl link with ppp multilink but i am not getting the desired bandwidth. Here is my configuration is this okay or i need something more in the configuration. My router is 2921 what is the maximum WAN throughput of 2921?
controller VDSL 0/0/0
controller VDSL 0/1/0
interface Multilink1
no ip address
ip virtual-reassembly in
ip virtual-reassembly out
ppp multilink
ppp multilink links maximum 4
ppp multilink group 1
ppp multilink fragment disable
ppp multilink mrru local 1492
ppp multilink mrru remote 1492
waas enable
interface Ethernet0/0/0
no ip address
interface Ethernet0/0/0.10
encapsulation dot1Q 10
pppoe enable group global
pppoe-client dial-pool-number 1
interface Ethernet0/1/0
no ip address
interface Ethernet0/1/0.10
interface Virtual-Template1
no ip address
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
ppp authentication pap callin
ppp pap sent-username ******** password 0 ********
ppp multilink
ppp timeout idle 2
ppp timeout multilink link remove 2
interface Dialer1
description line
mtu 1492
no ip address
ip route 0.0.0.0 0.0.0.0 Dialer0
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
You realize, unless you turn on fragmentation, a single flow will be limited to a single link's bandwidth?
Cisco documents maximum 2921 performance as 3.5 Gbps.  It also recommends 2921 for WAN links up to only 50 Mbps.
With ppoe's MTU of 1492, you might also be suffering from IP fragmentation.  IP TCP mss-adjust 1452 might help too.
+5
Dear Joseph,
I noticed in
Vi4 LCP: [Open]
Our Negotiated Options
Vi4 LCP:    MagicNumber 0xDF5B5F24 (0x0506DF5B5F24)
Vi4 LCP:    EndpointDisc 1 nth-connect.rtr1
Vi4 LCP:    (0x1313016E74682D636F6E6E6563742E72)
Vi4 LCP:    (0x747231)
Our Rejected options
  MRRU
Peer's Negotiated Options
Vi4 LCP:    MRU 1500 (0x010405DC)
Vi4 LCP:    AuthProto PAP (0x0304C023)
Vi4 LCP:    MagicNumber 0x416C2DE5 (0x0506416C2DE5)
Our Rejected options MRRU is showing does this need to be resolved?
