in test sample below everithing works correctly as expected ,
but problem is that if i change route-map dst "set ip next-hop 200.0.0.2 " to "set interface fastethernet 1/0"
than i am loosing conection to 222.222.222.222.
reason that i want to change route-map statement is that in reality one of my link is pppoe,
so i dont exactely know what will be the gateway next time router will take new ip.
i have two options
more prefered 1) leave defaulgt gateway assigned on pppoe and write PBR for second link for which i have gateway ip
less prefered 2) call provider and ask what can be the potential gateways , so that i can put all of them in "set ip next-hop verify-availibility x.x.x.x track xxx" command.
will be thankful, if someone can offer me better option.
interface FastEthernet0/0
description LAN
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip policy route-map dst
interface FastEthernet0/1
description isp1
ip address 100.0.0.1 255.255.255.0
ip nat outside
interface FastEthernet1/0
description isp2
ip address 200.0.0.1 255.255.255.0
ip nat outside
ip route 0.0.0.0 0.0.0.0 100.0.0.2
ip nat inside source route-map isp1 interface FastEthernet0/1 overload
ip nat inside source route-map isp2 interface FastEthernet1/0 overload
ip access-list extended dst
permit ip 10.0.0.0 0.0.0.255 host 222.222.222.222
ip access-list extended nat
permit ip 10.0.0.0 0.0.0.255 any
route-map isp2 permit 10
match ip address nat
match interface FastEthernet1/0
route-map isp1 permit 10
match interface FastEthernet0/1
route-map dst permit 10
match ip address dst
