PPPoE configuration
kolomja3
Hey guys,
I'm trying to setup my home internet on Cisco router. ISP is via PPPoE connection - NBN HFC (cable modem).
Here is my configuration and debug:
interface GigabitEthernet1
no ip address
pppoe enable group 42
pppoe-client dial-pool-number 42
interface Dialer1
mtu 1492
ip address negotiated
encapsulation ppp
dialer pool 42
dialer-group 42
ppp authentication chap callin
ppp chap hostname MY_ISP_NAME
ppp chap password MY_ISP_PASSWORD
IR800# sh pppoe session
Uniq ID PPPoE RemMAC Port VT VA State
SID LocMAC VA-st Type
N/A 0 0000.0000.0000 Gi1 Di1 N/A PADISNT
0000.0000.0000
IR800# sh ip int brief
GigabitEthernet1 unassigned YES unset up up
Dialer1 unassigned YES manual up up
Virtual-Access1 unassigned YES unset up up
Vlan1 unassigned YES unset up up
IR800#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
*Feb 27 06:41:32.179: Di1 DDR: ip (s=127.1.3.2, d=8.8.8.8), 100 bytes, outgoing uninteresting (dialer-list 42 not defined).
*Feb 27 06:41:34.180: Di1 DDR: ip (s=127.1.3.2, d=8.8.8.8), 100 bytes, outgoing uninteresting (dialer-list 42 not defined)..
*Feb 27 06:41:36.193: Di1 DDR: ip (s=127.1.3.2, d=8.8.8.8), 100 bytes, outgoing uninteresting (dialer-list 42 not defined).
*Feb 27 06:41:38.191: Di1 DDR: ip (s=127.1.3.2, d=8.8.8.8), 100 bytes, outgoing uninteresting (dialer-list 42 not defined).
Any advice why I can't receive PADO packet from ISP or why Dialer 1 int. can't find correct dialer-list?
Thank you
9 Replies 9
Georg Pauwen
do you have 'dialer-list 42 protocol ip permit' configured ? Post the full running configuration (sh run) of your router...
Hello George,
Here is full config:
! Last configuration change at 09:14:26 UTC Mon Feb 27 2023
version 15.7
hostname IR800
boot-start-marker
boot-end-marker
no aaa new-model
ppp syslog enable
service-module wlan-ap 0 bootimage autonomous
ignition off-timer 900
ignition undervoltage threshold 11
no ignition enable
ip cef
no ipv6 cef
chat-script lte "" "AT!CALL" TIMEOUT 20 "OK"
license udi pid IR829GW-LTE-GA-ZK9 sn FGL2436L87A
redundancy
controller Cellular 0
lte failovertimer 5
lte modem link-recovery disable
no cdp run
interface GigabitEthernet0
no ip address
shutdown
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface Wlan-GigabitEthernet0
no ip address
interface GigabitEthernet5
no ip address
shutdown
duplex auto
speed auto
interface Cellular0
encapsulation slip
dialer in-band
dialer idle-timeout 0
dialer string lte
dialer-group 1
ipv6 address autoconfig
interface Cellular1
no ip address
encapsulation slip
interface wlan-ap0
no ip address
interface Vlan1
no ip address
interface Async0
no ip address
encapsulation scada
interface Async1
no ip address
encapsulation scada
interface Dialer1
mtu 1492
encapsulation ppp
dialer pool 42
dialer-group 42
ppp chap hostname XXXX
ppp chap password YYYY
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
dialer-list 1 protocol ip permit
dialer-list 1 protocol ipv6 permit
ipv6 ioam timestamp
control-plane
line con 0
stopbits 1
line 1 2
stopbits 1
line 3
script dialer lte
no exec
transport preferred lat pad telnet rlogin lapb-ta mop udptn v120 ssh
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line 4
no activation-character
no exec
transport preferred none
transport input all
line 8
no exec
line 1/3 1/6
transport output none
stopbits 1
line vty 0 4
login
transport input none
no scheduler max-task-time
no iox hdm-enable
iox client enable interface GigabitEthernet5
no iox recovery-enable
end
the config looks good, at first glance. Run the debug commands below and post the output (after shut/no shut the dialer interface):
debug ppp authentication
debug ppp negotiation
debug pppoe event
All these debug options doesn't create any messages...(debug ppp authentication. negotiation, event)
I've enabled
debug pppoe packets
debug pppoe errors
debug pppoe events
*Feb 28 04:44:04.299: Sending PADI: Interface = GigabitEthernet1
*Feb 28 04:44:04.299: pppoe_send_padi:
contiguous pak, size 60
FF FF FF FF FF FF 64 3A EA 02 18 21 88 63 11 09
00 00 00 10 01 01 00 00 01 03 00 08 6A 00 00 01
00 00 1F 17 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00R800#sh pppoe session
1 client session
0000.0000.0000
IR800#ping 8.8.8.8
*Feb 28 05:09:31.699: Di1 DDR: ip (s=127.1.3.2, d=8.8.8.8), 100 bytes, outgoing interesting (ip PERMIT)
*Feb 28 05:09:31.699: Di1 DDR: Cannot place call, no dialer string set.
*Feb 28 05:09:33.700: Di1 DDR: ip (s=127.1.3.2, d=8.8.8.8), 100 bytes, outgoing interesting (ip PERMIT)
*Feb 28 05:09:33.700: Di1 DDR: Cannot place call, no dialer string set.
*Feb 28 05:09:35.700: Di1 DDR: ip (s=127.1.3.2, d=8.8.8.8), 100 bytes, outgoing interesting (ip PERMIT)
*Feb 28 05:09:35.700: Di1 DDR: Cannot place call, no dialer string set.
It's sending PADI frame out of correct interface as broadcast message but it never gets reply from svr.
I've tried cloning int G1 MAC address on my TP-Link router and it works. It doesn't look like issue on ISP side. I've verified with ISP that I can use CHAP authentication as well.
AstralVoyager
Hi bro wondering if this post is still active.
Is it solved? Recently I faced similar issue, if you could tell me the solution I'd be much appreciated.
vishalbhandari
@kolomja3 Your PPPoE session isn’t establishing because your Dialer1 interface isn’t associated with a valid dialer-list, which is causing packets to be marked as “uninteresting” and preventing the connection from bringing up the session.
Hi bro could you check my configuraiton? That'd be much appreciated!
I tried using CSR1KV and C8000v for home use with letting it act as PPPoE client and NAT gateway but with fail.
I almost searched for the whole internet for a resolution....When I use OpenWRT I just need to input my broadband username and password and then it works without any configuration, but for Cisco routers I tried many many times but failed
and I did some packet captures, modem already send c8000v PADO Active Discovery Offer, but Cisco router doesn't reply to modem at all. I put the capture file below:
and here's key configuration
ip address 10.0.0.8 255.255.255.0
ip nat inside
negotiation auto
no ip address
negotiation auto
pppoe enable group 1
pppoe-client dial-pool-number 1
interface Dialer1
mtu 1492
bandwidth 1000000
ip nat outside
encapsulation ppp
dialer pool 1
dialer persistent
dialer-group 1
ppp authentication pap callin
ppp pap sent-username username password 0 password
( I can make sure my ISP use PAP cleartext authentication because I checked it through openwrt capture )
ip access-list standard NAT_ACL
10 permit 10.0.0.0 0.0.0.255
Many thanks if you can take a look bro
Make new post please
MHM
ok bro thanks for notifying
