Prefix List and Access group
Heinz Kern
Is it possible to filter traffic on an interface with a prefix-list that references to the access-group command? somehting like that:
int gi0/0
ip access group Test in
ip prefix-list Test seq 10 permit 10.0.0.0/8
yes you can delete by sequence number to remove individual line in ip access-lists
5 Replies 5
Milos Megis
Level 3
Level 3
it is not possible.
Prefix list can be used only for control of routing information.
ok thanks for the information. at the end i wanted to achieve to delete ACL-entries individually. this is possible using an ip access-list instead of "standard access-list".
Hello
You can amend even standard acls without deleting the entire stanza
Example:
access-list 10 permit 1.1.1.1
access-list 10 permit 11.11.11.11
access-list 10 permit 111.111.111.111
sh access-lists
Standard IP access list 10 <-----------
    10 permit 1.1.1.1
    20 permit 11.11.11.11
    30 permit 111.111.111.111
ip access-list standard 10
no 20
sh access-lists
Standard IP access list 10 <----------- standard
    10 permit 1.1.1.1
res
Paul
Kind Regards
Paul
Mark Malone
No that's not going to work 2 separate features , you could do a distribute list in the process for the interface and match with a  prefix but you cant tie a prefix to an access-group
example
router eigrp 1
network 10.0.0.0
distribute-list TEST in g0/0
