Prefix List in BGP
kumarpmt83
We have one requirement in one my client location.
We configured two ISP(bsnl @ Tulip) in router with MPLS link and bgp protocol.
  LAN Network:10.10.150.0/23
  Bsnl ip : 192.168.36.96
  Tulip Ip : 10.237.9.65
Conf:
router bgp 65301
network 10.10.150.0 mask 255.255.254.0
neighbor 192.168.36.97 remote-as 9856
neighbor 10.237.9.64 remote-as 65002
We want allow traffic from 10.10.150.0/24 should go to Tulip link and the trafiic from 10.10.151.0/24 should go to Bsnl.
It is possible through prefixlist.
can u tell me how to configure the prefix-list.
14 Replies 14
Tagir Temirgaliyev
ip route 10.10.150.0 255.255.255.0 GigabitEthernet0/0              --- put your connected int here
ip route  10.10.151.0 255.255.255.0  GigabitEthernet0/0             --- put your connected int here
ip prefix-list 1_LN seq 5 deny 10.10.150.0/24
ip prefix-list 1_LN seq 10 permit 10.10.151.0/24
ip prefix-list 2_LN seq 5 deny 10.10.151.0/24
ip prefix-list 2_LN seq 10 permit 10.10.150.0/24
router bgp 65301
no network 10.10.150.0 mask 255.255.254.0        --- you do not advertise this network
network 10.10.150.0 mask 255.255.255.0           --- you will advertise two more networks insted
network 10.10.151.0 mask 255.255.255.0           ----
neighbor 192.168.36.97 prefix-list 1_LN out
neighbor 10.237.9.64 prefix-list 2_LN out
thus from one provider incoming traffic only will came to one network and from second to second
dont forget to rate post if helpfull
why u put static route in this configuration?
because BGP will only advertise those routes whith are exist in routing table
i am not undrstand .can u tell me in clearly
as for outgoing traffic for routing based on source address should be used PBR
Thanks for your support
As lastly remarked by ttemirgaliyev, if you want to route differently according to source address then you have to use PBR( Policy based routing).
-On the interface where the src IP arrives: ip policy route-map PBR
-in global config:
access-list 50 permit 10.10.150.0 0.0.0.255
access-list 51 permit 10.10.151.0 0.0.0.255
route-map PBR permit 10
match ip address 50
set ip next-hop 10.237.x.x       Tulip IP
match ip address 51
set ip next-hop 192.168.x.x     Bsnl  IP
Regards.
Alain
Now what am i to do for my requirement
I am to  apply the Both prefix-list and PBR or anyone .
you have to use the PBR as you want to route differently according to source IP but a router routes according to destination subnet only. So don't use the prefix-list.
Regards.
Alain.
Thanks for ur valuable support.
Hello Dhineshkumar,
it is better if you use only PBR as the first solution with prefix-lists defeats BGP multi-homing by filtering IP prefixes sent to the providers
Also your requirement is on source IP address so PBR is the tool to use.
Hope to help
Giuseppe
Thanks for ur support
Hello Alain,
it is just a typing mistake for sure but two route-map clauses are needed
match ip address 50
route-map PBR permit 20
match ip address 51
Hope to help
Giuseppe
Hi giuseppe,
of course , good catch
Regards.
Alain.
