Prevent IOS router from advertising sub-network in a large network BGP
dhr.tech1
Introduction
In this blog we will try to explain how we can  prevent an IOS router from advertising a specific sub-network in a large advertise network BGP. We cannot filter the route if we're advertising the routes using a Null Route.
When you inject a route into BGP using a network statement backed by a Null0 static route (e.g., 10.0.0.0/8 → Null0), BGP only sees and advertises the summary. It has no visibility into smaller subnets like 10.20.20.0/24 unless they are also present in the routing table. So, trying to block such subnets using a route-map has no effect, because BGP isn’t advertising them to begin with.
Topology
Initial Configuration
R1
interface Loopback1
ip address 10.10.10.1 255.255.255.192
interface Loopback2
ip address 10.10.10.65 255.255.255.192
interface Loopback3
ip address 10.10.10.129 255.255.255.192
interface Loopback4
ip address 10.10.10.193 255.255.255.192
interface GigabitEthernet0/0
ip address 11.11.11.1 255.255.255.0
duplex auto
speed auto
media-type rj45
router bgp 100
bgp log-neighbor-changes
network 10.10.10.0 mask 255.255.255.192
network 10.10.10.64 mask 255.255.255.192
network 10.10.10.128 mask 255.255.255.192
network 10.10.10.192 mask 255.255.255.192
aggregate-address 10.10.10.0 255.255.255.192
neighbor 11.11.11.2 remote-as 200
R2
interface Loopback1
ip address 20.20.20.1 255.255.255.192
interface Loopback2
ip address 20.20.20.65 255.255.255.192
interface Loopback3
ip address 20.20.20.129 255.255.255.192
interface Loopback4
ip address 20.20.20.193 255.255.255.192
interface Loopback5
shutdown
ip address 11.11.11.2 255.255.255.0
duplex auto
speed auto
media-type rj45
router bgp 200
network 20.20.20.0 mask 255.255.255.0
neighbor 11.11.11.1 remote-as 100
Initial Verification
R2R1
Objective: Ensure route 10.10.10.192/26 isn't advertised from R1 to R2.
Technical changes
R1
ip prefix-list deny_subnet seq 5 deny 10.10.10.192/26
ip prefix-list deny_subnet seq 10 permit 0.0.0.0/0 le 32
route-map suppress_subnet permit 10
match ip address prefix-list deny_subnet
router bgp 100
neighbor 11.11.11.2 route-map suppress_subnet out
Final Verification
R2 -Before changeR2 -After Change
0 Replies 0
