Prevent one vlan to acess other vlans
ittechk4u1
Level 4
Level 4
Hello experts,
I have following VLANs:
int vlan1
des *** Guest
ip add 192.168.1.0/24
int vlan2
des***Data1
Ip add 192.168.2.0/24
int vlan 3
des ***Data2
Ip add 192.168.3.0/24
int vlan 4
des ***Data3
Ip add 192.168.4.0/24
What i need to achieve:
Scenario1:
1. Block all communication from VLAN1 to other VLANs(2,3,4).
2. Other VLANs(2,3,4) must have access to VLAN1.
Scenario2:
1.Block all communication from VLAN1 to other VLANs(2,3,4).
2. Other VLANs(2,3,4) must also not have access to VLAN1.
Can anyone help me to create acl or any other method to find a solution for it.
try add the acl to the vlan 2 interface as well
8 Replies 8
Mark Malone
Scenario 2 = block vlan 1 speaking to each other vlan and then reverse it block vlan 2,3,4 speaking into vlan 1 , apply the acl to vlan 1 interface
from this you can easily work out scenario 1 if you need to , another way would be use vrfs as another solution
access-list 108 deny   ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 108 deny   ip 192.168.1.0 0.0.0.255 192.168.3.0 0.0.0.255
access-list 108 deny   ip 192.168.1.0 0.0.0.255 192.168.4.0 0.0.0.255
access-list 108 deny   ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 108 deny   ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 108 deny   ip 192.168.4.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 108 permit ip any any
int vlan 1
ip access-group 108 in
ip access-group 108 out
I think this for for scenario2:
int vlan 1
is it correct ?
what will be the acl for scenario1?
that's exactly what I posted for scenario 2 , scenario 1 would have permit statements like below as its allowing to speak vlans 2,3,4 as you stated they must have access to vlan 1
access-list 108 permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 108 permit ip 192.168.3.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 108 permit ip 192.168.4.0 0.0.0.255 192.168.1.0 0.0.0.255
int vlan 1
Thanks again.
Scenario2 is working but not scenario1.
Here i did for scenario1:
interface Vlan1
 ip address 192.168.1.254 255.255.255.0
interface Vlan2
 ip address 192.168.2.254 255.255.255.0
Output:
SWITCH#ping 192.168.2.254 source vlan 1
Sending 5, 100-byte ICMP Echos to 192.168.2.254, timeout is 2 seconds:
Packet sent with a source address of 192.168.1.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
SWITCH#ping 192.168.1.254 source vlan 2
Sending 5, 100-byte ICMP Echos to 192.168.1.254, timeout is 2 seconds:
Packet sent with a source address of 192.168.2.254
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/9 ms
SWITCH#
Where i am doing the mistake ?
yes,now with this conifg, it is working:
interface Vlan1
interface Vlan2
Thanks again.
cool good stuff
Julio E. Moisa
Other option is using Vlan ACLs.(VACL)
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
