Restrict SSH, TELNET and HTTP ro Management VRF on ISR 400
richardadeolu
Dear all,
Is there any way to limit access to http, telnet and ssh to the router on other intefaces except the manangement vrf?
I can use accessliest and access class on the VTY lines, and restich http to only managment subnet, but am looking for a way to do this without using access-lists.
I was under the impression that this is why te management interface/vrf was created for.
Am I thinking wrong?
6 Replies 6
elnurh
I think  there are only access-list and access class for limit access to router itself. You can  also use access list to all interface to deny access to router itlsef except mgmt interface where you can show from which host  can access to mgmt interface.
Collin Clark
Control Plane Protection is the best way (IMO), but you can also do it with Control Plane Policing or just QoS.
But in my version, there is no control-plane management.
I can only do control-plane host and i do not see how I can configure the router to accept SSH, HTTP and Telnet via this way.
Mind elaborating?
ROUTER#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
ROUTER(config)#control-plane host
ROUTER(config-cp-host)#management-interface vlan13 allow ssh ftp snmp
This would allow ssh, ftp and snmp only from VLAN 13.
jason.emery
Not sure this is the right answer, but here is what I did on ISR 4431.
Create some bogus interface such as:
int g0/0/1.1
desc bogus_mgmt_intf
shut
Then set the control plane policing to only allow that interface:
# control-plane host
# management-interface G0/0/1.1 allow snmp
# exit
Seems to work great - I can still access through Gi0 Mgmt_intf vrf but cannot access externally from any other IP interface.
Hi Jason MPP is not fully operational on the ios-xe series be careful with it , we deployed it and found out after some of  the MGMT protocols are not programmed fully and supported, we have an open feature request with our Cisco acc manager to enable it fully in the next release , its seems to break with ssh , snmp works fine
 http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
From the link above you can select the feature "Management plane protection" and you will find the supported platforms. Unfortunately this is not yet  supported on IOS-XE platforms. Digging internally I could find an enhancement bug as well to add this feature for IOS-XE which was raised earlier  however the DDTS was in closed  since there was no relevant request raised at that time. You may find the DDTS information from the link below:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCts41086/?reffering_site=dumpcr
