Problème with Offloading
dami91
Hello
Can you explane me how to configure the offloading ? thank you
XXXXXXXXXXXXX#show route-map
route-map PBR-OFF, permit, sequence 10
Match clauses:
ip address (access-lists): DSCP_OFFLOAD
Set clauses:
ip next-hop verify-availability 86.79.0.66 1 track 10 [down]
Policy routing matches: 179039 packets, 39271064 bytes
XXXXXXXXXXXXXXXXX#Connection closed by foreign host.
a.alekseev
Level 7
Level 7
What are you trying to do?
j'essaye de configurer le offloading entre le routeur nominal et backup , puisque maitenant tout le trafic passe via le nominal l'offloading est ko
I try to configure the offloading between the nominal router and backup, since now all the traffic passes via the nominal the offloading is ko
