problem ASR 903 copy ios to stanby RSP
Dhikra Marghli
Level 5
Level 5
Hello
I have ASR 903  cisco and i upgrade IOS so the problem :
i want to copy RSP2  and image 16.9.4   from bootflash  ( RSP  ACTIVE ) to stanby RSP but it is not work this command
ASR903-ELGHAZELA-NEW#copy bootflash: stby-bootflash:
Source filename [rsp2_15_6_30r_s_rommon.pkg]?
Destination filename [rsp2_15_6_30r_s_rommon.pkg]?
%Error opening stby-bootflash:/rsp2_15_6_30r_s_rommon.pkg (I/O error)
so  i wait from expert ASR 900 answer me and give me what i can doing that allow me copy image to stanby rsp  bacause i can't copy to stanby ??
thanks in advance
2 Accepted Solutions
@Dhikra Marghli wrote:
Directory of stby-bootflash:/
No files in directory
1339412480 bytes total (632262656 bytes free)
The chassis is running on 3.18.1 with a very high uptime.
I suspect this is a bug -- reboot the entire chassis and try again.
balaji.bandi
Config regiter we expect to be
config-reg 0x2102
before you make this change as suggested reload RP since Long uptime may have issue, and try copy ?
BB
14 Replies 14
Dhikra Marghli
Level 5
Level 5
i want  from expert ASR 900 help me and say  me what is the command  that allow do a copy from rsp active to rsp stanby (  rsp2_15_6_30r_s_rommon.pkg ////
asr900rsp2-universalk9_npe.16.09.04.SPA.bin )
thanks in advance
Leo Laohoo
Post the complete output to the following command:
dir stby-bootflash:
dir stby-bootflash:
ASR903-ELGHAZELA-NEW#dir bootflash:
Directory of bootflash:/
11 drwx 16384 Mar 20 2017 06:28:03 +00:00 lost+found
45313 drwx 4096 Mar 20 2017 07:14:38 +00:00 .prst_sync
60417 drwx 4096 Mar 20 2017 07:40:27 +00:00 Image
15105 drwx 4096 Mar 20 2017 06:31:11 +00:00 .installer
12 -rw- 149915 Nov 25 2020 23:42:16 +00:00 SYSMEM20201125.dat
15106 drwx 4096 Mar 20 2017 08:05:12 +00:00 core
13 -rw- 149938 Nov 26 2020 23:43:13 +00:00 SYSMEM20201126.dat
120833 drwx 24576 Dec 1 2020 09:53:17 +00:00 tracelogs
14 -rwx 14387 Mar 20 2017 06:48:11 +00:00 tracelogs.935
30209 drwx 4096 Mar 20 2017 07:12:49 +00:00 .rollback_timer
105729 drwx 4096 Mar 20 2017 07:13:56 +00:00 virtual-instance
15 -rw- 149915 Nov 27 2020 23:44:09 +00:00 SYSMEM20201127.dat
16 -rw- 149915 Nov 28 2020 23:45:05 +00:00 SYSMEM20201128.dat
17 -rw- 149915 Nov 29 2020 23:46:02 +00:00 SYSMEM20201129.dat
18 -rw- 149915 Nov 30 2020 23:46:58 +00:00 SYSMEM20201130.dat
19 -rw- 62564 Dec 1 2020 09:47:22 +00:00 SYSMEM20201201.dat
20 -rw- 149915 Nov 23 2020 23:40:23 +00:00 SYSMEM20201123.dat
21 -rw- 149915 Nov 24 2020 23:41:20 +00:00 SYSMEM20201124.dat
22 -rw- 539600 Dec 1 2020 09:16:00 +00:00 rsp2_15_6_30r_s_rommon.pkg
23 -rw- 402478045 Dec 1 2020 09:19:04 +00:00 asr900rsp2-universalk9_npe.16.09.04.SPA.bin
1339412480 bytes total (224436224 bytes free
this is output and i wait a reply   and answer why this command do not work ???? what is the solution !!
thanks in advance
Can you post below output :
#show platform
# dir
#show version
BB
19 -rw- 65686 Dec 1 2020 10:17:23 +00:00 SYSMEM20201201.dat
1339412480 bytes total (224428032 bytes free)
ASR903-ELGHAZELA-NEW#show platform
Chassis type: ASR-903
Slot Type State Insert time (ago)
0/0 A900-IMA8S1Z ok 2y14w
0/1 A900-IMA8S1Z ok 2y14w
0/2 A900-IMA8S1Z ok 2y14w
0/3 A900-IMA8S ok 2y14w
0/4 A900-IMA8S ok 2y14w
R0 A900-RSP2A-128 ok, active 2y14w
R1 A900-RSP2A-128 ok, standby 2y14w
F0 ok, active 2y14w
F1 ok, standby 2y14w
P0 A900-PWR550-D-E ok 2y14w
P1 A900-PWR550-D-E ok 2y14w
P2 A903-FAN-E ok 2y14w
Slot CPLD Version Firmware Version
R0 15092360 15.4(3r)S5
R1 15092360 15.4(3r)S5
F0 15092360 15.4(3r)S5
F1 15092360 15.4(3r)S5
ASR903-ELGHAZELA-NEW#show version
Cisco IOS XE Software, Version 03.18.01.S - Extended Support Release
Cisco IOS Software, ASR900 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.6(2)S1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 28-Jun-16 08:21 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ASR903-ELGHAZELA-NEW uptime is 2 years, 14 weeks, 6 days, 2 hours, 35 minutes
Uptime for this control processor is 2 years, 14 weeks, 6 days, 2 hours, 38 minutes
System returned to ROM by reload
System image file is "bootflash:Image/packages.conf"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: metroaggrservices
License Type: Permanent
Next reload license Level: metroaggrservices
cisco ASR-903 (RSP2) processor (revision RSP2) with 918570K/6147K bytes of memory.
Processor board ID FOX2052PBTB
40 Gigabit Ethernet interfaces
3 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3670016K bytes of physical memory.
1328927K bytes of SD flash at bootflash:.
Configuration register is 0x2
i give three output so what is the problem for stanby RSP  and what is command that allow copy from bootflash to stanby rsp !!!
i wait a reply and a help
thanks
NO  , to day i try to copy USB0:   Bootflash :
( RSP2  and  ASR asr900rsp2-universalk9_npe.16.09.04.SPA.bin )  to rsp active
so  the second srep :
i want to copy two file  from bootflah to rsp stanby  !!!
so this  :
Source filename []? rsp2_15_6_30r_s_rommon.pkg
this is my problem about copy to stanby rsp !!
so what is the solution and i wait a answer that help me !!
thanks
Hello @Dhikra Marghli ,
the command logic should be copy <source-file>  <destination-file>
try the following
copy bootflash:rsp2_15_6_30r_s_rommon.pkg stby-bootflash:rsp2_15_6_30r_s_rommon.pkg
Hope to help
Giuseppe
Thanks to reply me
ASR903-ELGHAZELA-NEW#copy bootflash:rsp2_15_6_30r_s_rommon.pkg stby-bootflash:rs
ASR903-ELGHAZELA-NEW#copy bootflash:rsp2_15_6_30r_s_rommon.pkg stby-bootflash:rsp2_15_6_30r_s_rommon.pkg
i try  this comand but it is not work  !!! ???
I try and i tell you soon !!
thanks to reply me !!
balaji.bandi
Follow below guide :
https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/xe-16-9/asr1000-software-config-guide-16-9/app-b-asr.html
BB
i don't understand you !!
why i put this command ??,
please can you explain me !!
balaji.bandi
config-reg 0x2102
BB
Ok  , i try  and i tell you
thanks again
