Problem between Routers ASR 920 with Rapid PVST and switch with RSTP
AmilcarDD
Dear Sirs,
We have encountered an issue whan connecting a switch with RSTP redundancy to a redundant Cisco ASR 920 arrangement.
Each router is connected to the adjacent router, by a *tp cable in each site and by fiber optic to other sites.
The routers are configured for Rapid PVST.
Based on the behaviour, it seems the Cisco Routers are unaware of the second ring that exists locally through the switch, and are constantly shuting down the ports, probably due to storm detection or the likes.
Can you advise on how we should change the configuration of the router ports that are connected to the switch, in order to obtain stable operation ?
Both routers have the identical configurations:
spanning-tree mode rapid-pvst
no spanning-tree vlan 90-95,410-415
spanning-tree vlan 190-195 priority 4096
sdm prefer default
diagnostic bootup level minimal
interface GigabitEthernet0/0/5
description [GSEXT] SCADA LAN
no ip address
no ip proxy-arp
load-interval 30
shutdown
media-type auto-select
negotiation auto
storm-control broadcast level 10.00
storm-control action shutdown
service-policy input PM_IN
service instance 194 ethernet
description LAN SCADA
encapsulation untagged , dot1q 194
l2protocol peer stp
bridge-domain 194
interface GigabitEthernet0/0/10
description == Link Router 1 to Router 2 Gi0/0/10 ==
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
negotiation auto
cdp enable
service-policy output PM_OUT
service instance 90 ethernet
description P2P 1
encapsulation dot1q 90
rewrite ingress tag pop 1 symmetric
bridge-domain 90
service instance 92 ethernet
description P2P 2
encapsulation dot1q 92
bridge-domain 92
service instance 93 ethernet
description P2P 3
encapsulation dot1q 93
bridge-domain 93
service instance 94 ethernet
description P2P 4
encapsulation dot1q 94
bridge-domain 94
service instance 95 ethernet
description P2P 5
encapsulation dot1q 95
bridge-domain 95
service instance 190 ethernet
description LAN 6
encapsulation dot1q 190
l2protocol peer stp
bridge-domain 190
service instance 192 ethernet
description LAN 7
encapsulation dot1q 192
l2protocol peer stp
bridge-domain 192
service instance 193 ethernet
description LAN 8
encapsulation dot1q 193
l2protocol peer stp
bridge-domain 193
description LAN 9
encapsulation dot1q 194
l2protocol peer stp
bridge-domain 194
service instance 195 ethernet
description LAN 10
encapsulation dot1q 195
l2protocol peer cdp stp
bridge-domain 195
service instance 1024 ethernet
bridge-domain 1024
15 Replies 15
Hello
I would try and use the same if applicable- in either case i would suggest you need to make sure its enabled for ALL vlans on all switching hardware that is running  L2 and tagging including those rts if they are doing L2 also
However care must be taken -I do not understand your topology fully to say go ahead and do such changes - you need to be mindful of any changes you make especially if it effects hardware you do not administer
Kind Regards
Paul
