Problem configuring 881 for PPPoE
wcjiang
Community Member
Hi, I had configured an 871 to use PPPoE before. Now I tried to use the same configuration on a new 881, I was able to connect to the Internet from the router, but my PC behind the 881 cannot ping any public address except the one on the WAN interface. Has anyone had similar experience? Below is my config. I also tried using the ccpexp, but it doesn't have a wizard like before, just a simple flash page, no pppoe.
vpdn enable
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin ppp pap sent-username pe1012@sbcglobal.net password x68mTE
ppp ipcp dns request ppp ipcp address accept
dialer-list 1 protocol ip list 1
ip nat inside source list 1 interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
interface FastEthernet4
pppoe-client dial-pool-number 1
ip nat outside
ip route-cache flow
duplex auto
speed auto
ip nbar protocol-discovery
interface Vlan1
ip address 10.10.10.1 255.255.255.0
ip route-cache flow
ip tcp adjust-mss 1452
access-list 1 permit 10.10.10.0 0.0.0.255
hi
plese change it
vpdn enable
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
ip nat outside
pppoe enable group global
no ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Vlan1
ip route-cache flow
ip nat inside
ip route 0.0.0.0 0.0.0.0 interface dialer 1 overload
show ip interface brief
check you are getting ip on your dialer interface
if not contact your ISP for specific dialer settings.
Jawad
Jawad
5 Replies 5
Reza Sharifi
Can you add
ip nat inside
to vlan 1 and test again?
Thank you for your reply, I did have that in there, somehow I didn't paste that in the post above:
ip nat inside
ip virtual-reassembly
ip route-cache flow
I started with a working configuration for DHCP and modified the WAN interface to use PPPoE, so the LAN part was working when I connected the 881 behind another router using DHCP, my PC could connect to the Internet through the two routers.
hi
plese change it
vpdn enable
interface Dialer1
encapsulation ppp
dialer pool 1
dialer-group 1
ip nat outside
no ip nat outside
ip route-cache flow
duplex auto
speed auto
interface Vlan1
ip route-cache flow
ip nat inside
Jawad
Jawad
Thank you, I will try that when I get to the office next week. I did type in pppoe enable group global, but when I ran "show running-config" this line was not shown, I was wondering why. I assumed it was the default. I also tried changing Dialer1 to dialer 0, didn't work either. When I typed "ip show route" I could see the public IP address assigned to the WAN by the ISP and the next hop, so that part was working. As I said I could ping any public IP address from the router, so I suspect the problem is the routing/permission from LAN to WAN. But the routing worked when I used DHCP.
Thank you very much, apparently with the new firmware ip nat outside needs to be under the Dialer interface. I ended up installing CCP on my PC and using that to generate the basic commands.
