Problem DHCP on L3 Switch
join_sn09
Dear Expert and All,
I would like to ask you some quetion on DHCP, i had switch 6509 and all the client provide DHCP
by this switch and never release . I currently 100 user. and i setp DHCP start from 10 to 250. Last time
all the client used from 10-100.So on client ip 20,21,22,23 is doesn't work (i mean now not use this
ip address but it remmaber on switch)so when i take the new computer to plug on the switch it start for 101.
My question: Which command that release ip 20,21,22,23 and the new client renew ip 20,21,22,23?( I mean don't
want the new client catch ip start from 101 because ip 20,21,22,23 is free)
Could you advice Please?
Best Regards,
Join
hadbou
Level 5
Level 5
"set interface sc0 dhcp release" is the command used to release the ip address assigned by DHCP
"set interface sc0 192.20.11.44/255.255.255.0" is the command used to assign a new no dhcp ip address.
"set interface sc0 dhcp renew" is the command to renew the DHCP assigned ip address.
For more information on this command refer:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/command/reference/set_f_l.html#wp1025833
Dear Hadbou,
thanks you for your advice.
The command that you gave me for OS but my switch is IOS.
Could you give me some command for IOS?
and i would like to know which command that we can release one or two IP not all.:)
Best Regards,
Join
