Problem for removed Flexible Netflow on 3850
Hello everyone and thank you in advance for your help
I am trying to edit/modify/delete the current configuration of Flexible Netflow V. 9 on an cisco catalyst 3850. But I can't delete it :
% Flow monitor: "Flow Record" is in use. Remove from all interfaces before deleting
However when I use the command "show flow monitor", no flow monitor is applied
my version of IOS is as follows: 16.6.5.
Has anyone ever encountered this bug and knows a solution?
If you can help me
Mark Elsen
 - Make sure tto  use the no ip flow monitor command to remove a flow monitor from all of the interfaces to which you have applied it before , then check again.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Hi !
Yes i did it for all the interfaces.
But, the message is still here :
% Flow Monitor: 'ipv4_netflow_input' is in use. Remove from all interfaces before deleting
And, when I use "show flow interface", there is nothing.
this is the 2nd time this has happened to me, but I don't find a solution ...
