Problem from VRF Global to VRF Internet Natting
ranjit123
Level 3
Level 3
Hello All,
I have the below issue
I have a lan interface which is part of VRF global
interface GigabitEthernet0/0
ip address
ip nat inside
and WAN interface which is part of another VRF and has a public IP
interface gi0/1
 ip vrf forwarding internet
ip address public IP
ip nat outside
Also i have configured nat overload on this WAN interface as below
ip nat inside source list <name> interface GigabitEthernet0/1 overload
and done inter vrf routing
when i trace from the router for the IP's added in the source-list the trace works fine
but when i do a telnet on port 80 the IP's listed in the source list the port does not open and ICMP does not work.. ( these are working from internet)
Also i see hits in the nat translation table as below
router#show ip nat translations
Pro Inside global Inside local Outside local Outside global
udp <IP>:49154 <IP>:49154 <IP>:33434 1<IP>:33434
udp <IP>:49155 <IP>:49155 <IP>:33435 <IP>33435
udp <IP>:49156 1<IP>:49156 <IP>:33436 <IP>:33436
udp <IP>:49157 <IP>:49157 <IP>:33437 <IP>:33437
udp <IP>:49158 1<IP>:49158 <IP>:33438 <IP>:33438
Because of which the natting is not working... i also tried NAT NVI but it also does not work..
Any workaround..
Ranjit
5 Replies 5
Julio E. Moisa
Usually the Internet is handled by the global table, are you using VRF for the Internet as well? are you importing the route-targets into each other, you could see if the data VRF subnets are into the Internet VRF.
And if your G0/1 is configured to be part of a VRF, the NAT should be configured as well.
ip nat inside source list 1 interface g0/1  vrf internet
But I dont remember if it is supported for overload.
Usually to get Internet access through the global (global is not part of any VRF) for your VRF, you should configure:
ip route vrf VRF-NAME 0.0.0.0 0.0.0.0 GigabitEthernet 0/1 <The IP of the next hop> global
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hello julio can you please provide me ur email ID..
You can contact me through ju.mois78@gmail.com
thanks
It does support overload, so I think you just need:
ip nat inside source list <name> int gi0/1 vrf internet overload
ip route vrf internet 0.0.0.0 0.0.0.0 gi0/1 <gateway ip>
as Julio suggested
