Problem in routing between VLANS on Nexus 5020
Dear
 I hope you are doing well.
I have a problem with Nexus 5020. The command "IP routing" is missing. so I can not access any device in any other VLAN.
Is there any solution for this problem. or this model doesn't support routing between VLANs
9 Replies 9
is the option 'feature interface-vlan' available ?
Yes It it available and it is activated
Does the Nexus switch does not support "ip routing command"
no, I don't think so. Enabling the 'feature interface-vlan' allows you to create SVIs (Vlan interfaces), and inter-Vlan routing should be enabled by default.
is this switch a layer 2 or a layer 3 switch
I checked again, apparently, the 5010/5020 models are layer 2 only and do not support routing and/or routing protocols.
Does any firmware upgrade solve this problem?
both the 5010 and the 5020 are end of life as of 2012. There is no upgrade, or anything else to get these switches to have layer 3 functionality. They are layer 2 only...
Cisco note.
Note
Make sure the LAN Base Services license is installed on the switch to enable Layer 3 interfaces.
@MHM Cisco World
--> Make sure the LAN Base Services license is installed on the switch to enable Layer 3 interfaces.
Interesting. Where did you find this information, do you have a link ?
