Problem in static route to a Dialer interface
kamel4
I have a Router_A which has 1 ISP via Dialer interface and Router_B which stopped communicating with Router_A.
Due to changing of Dialer ip since it is dynamic, every time the ip address of dialer changes, I need to update the static route in Router_B to be able to reach Router_A. is there a better solution?
Note:
Router_B has default route 0.0.0.0 0.0.0.0 to Router_DC only for internet browsing but for reachability to other branch offices we only static routes.
Hello
on the dialer interface apply ppp ipcp route default and remove the static default, then you should receive a ppp default from the ISP automatically.
int dialer x
Kind Regards
Paul
