Copy HTTPS://x.x.x.x/dir flash: (I/O error)
Plantern
Community Member
I am trying to copy a file from an HTTPS (Apache2 - self signed cert) server from a CAT9300 running Cisco IOS XE Software, Version 16.12.04. I encounter the following error:
%Error opening https://10.10.10.10/hello.txt (I/O error)
200982: *Sep 28 2021 12:10:10.178 LOCAL: http_client_request:
200983: *Sep 28 2021 12:10:10.178 LOCAL: httpc_setup_request:
200984: *Sep 28 2021 12:10:10.178 LOCAL: httpc_setup_request:Source interface =
200985: *Sep 28 2021 12:10:10.178 LOCAL: http_client_process_request:
200986: *Sep 28 2021 12:10:10.178 LOCAL: http_client_process_request: host_name = 10.10.10.10
200987: *Sep 28 2021 12:10:10.178 LOCAL: http_client_process_request: transaction url = 10.229.128.54/hello.txthttpc_request: Dont have the credentials
200988: *Sep 28 2021 12:10:10.178 LOCAL: FIBipv4-packet-proc: route packet from (local) src x.x.x.x dst x.x.x.x
200989: *Sep 28 2021 12:10:10.178 LOCAL: FIBfwd-proc: packet routed by adj to Vlan1200 x.x.x.x
200990: *Sep 28 2021 12:10:10.178 LOCAL: FIBipv4-packet-proc: packet routing succeeded
200991: *Sep 28 2021 12:10:10.178 LOCAL: IP: tableid=0, s=x.x.x.x (local), d=x.x.x.x (Vlan1200) nexthop=x.x.x.x, routed via FIB
200992: *Sep 28 2021 12:10:10.178 LOCAL: IP: s=10.229.129.2 (local), d=x.x.x.x (Vlan1200), len 48, sending
200993: *Sep 28 2021 12:10:10.178 LOCAL: TCP src=47822, dst=443, seq=946866756, ack=0, win=65535 SYN
201006: *Sep 28 2021 12:10:20.178 LOCAL: http_transaction_free:
201007: *Sep 28 2021 12:10:20.178 LOCAL: http_transaction_free: freed httpc_transaction_t with id 62
201008: *Sep 28 2021 12:10:20.179 LOCAL: http_client_abort_request:
http_client_abort_request: Bad Transaction Id
I was wondering if anyone who has had this issue and has found a fix could help out. I am aware of an old post from 2013 which described a similar issue but there is no explanation on how the problem was resolved. Thanks.
p.s. IMO server side configuration (FW included) is correct.
13 Replies 13
balaji.bandi
the Syntax should be  as below :
HTTPS—https:[[//username [:password]@location]/directory]/filename
worth check thing the bug : ( check the Block size)
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvq01204
BB
Plantern
Community Member
Thank you for your reply. I use the syntax correctly but to no avail. Or am I?
copy https://admin:admin@10.10.10.10/var/www/html/hello.txt flash:hello.txt
It seems that the error message is the same whether the credentials are used or not.
The block size bug does not apply in this instance.
ok are you able to use any other means to test isthe copy working on flash ?
example TFTP or FTP ?
BB
I am currently testing exactly that. I will give an update here once testing is finished. Thank you for your reply.
It seems that copying with SCP works. I am unsure how to force the device to trust the self signed apache2 cert.
Can you try it with HTTP? You mentioned that the server is using a self-signed certificate. You will have to install a trust point for the router to trust that CA.
hello,
I was thinking that this most likely is the issue. I just wish there was a small guide on how to set up the trust point for the router to trust this CA (apache2). I have tried simply:
crypto pki trustpoint apache2
enrollment url https://10.10.10.10
This obviously did not work. Perhaps you would be kind to send a link that could guide me a bit in the right direction? Thank you.
mgrabovs
Looking at the fact that we're getting I/O errors, they are directly related to a possible HW failure of the disk.
Before ruling any sort of conclusion, I suggest doing a filesystem check to the destination filesystem that you want to copy the file to.
If you want to copy the file to flash:, then the command would look like this:
# fsck flash:
Or to whatever filesystem you want to copy to:
# fsck <filesystem>
Thank you.
Marin Grabovschi
I have the same error on all network components within the network. Not only on the c9300. Everyone (all devices) seem to have the same outcome.
Georg Pauwen
what exactly are you running the Apache 2 on ? I wonder if the error is caused by the server. Does that work from a 'normal' PC/laptop ?
The Apache2 is ran as a VM.
Leo Laohoo
CSCvx38476
