Problem pinging from VLAN1
retosteinemann
Community Member
I have a problem with my Cisco 887V VDSL-router. The router gets a ip-address with dhcp from my provider. That works fine. I also can ping from the router:
routerVdslTestNew#ping google.ch source vlan 1
Sending 5, 100-byte ICMP Echos to 74.125.79.99, timeout is 2 seconds:
Packet sent with a source address of 10.10.10.1
Success rate is 100 percent (5/5), round-trip min/avg/max = 48/48/52 ms
My problem: If I want to ping google from a computer in the VLAN1 the ping doesn't work.
C:\Users\XXXXXX>ping 74.125.79.99
Ping wird ausgeführt für 74.125.79.99 mit 32 Bytes Daten:
Timeout.
What did I configure wrong? The configuration is attached to this post.
Thanks!
In config mode reenable ip routing with the ip routing command.
Regards.
Alain.
mrdogantr
Level 6
Level 6
can you post "sh ip int brie" and "sh ip nat trans" outputs.
Regards.
Alain.
Thank you! That was it.
