Problem port forward Router 1841
Hello guys
I tried to connect a FTP Server in CentOS
i need a port forward for access from internet, i specify in config port forward but doesn't work
Thanks a lot!
Router#show running-config
Building configuration...
Current configuration : 2404 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
clock timezone Santiag -4
clock summer-time Santiag date Mar 9 2003 12:00 Oct 26 2003 2:00
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool InternalIP
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 200.28.4.130 200.28.4.129
ip ips po max-events 100
no ftp-server write-enable
interface FastEthernet0/0
no ip address
ip tcp adjust-mss 1452
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface FastEthernet0/1
description $FW_INSIDE$$ETH-LAN$
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface Dialer0
description Conect to ONLINE$FW_OUTSIDE$
ip address negotiated
ip mtu 1454
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username XXXXXXXXXXXXX password 0 XXXXXX
interface Dialer20
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 192.168.1.123 22 interface Dialer0 22
ip nat inside source static tcp 192.168.1.123 21 interface Dialer0 21
ip nat inside source static tcp 192.168.1.123 20 interface Dialer0 20
When you say it is not working from the internet, how do you test it? from a host on the internet or from a host inside by specifying the outside public address? if the latter then it won't work because NAT hairpinning is not supported by the Cisco devices.Also as a sidenote the MTU should be 1492 if you set the MSS to 1452 because the IP header is more than 2 bytes( you put the MTU to 1454 !!).
Alain
7 Replies 7
cadet alain
How did you test it ? Is it working when accessing the private IP from the LAN ? Have you verified there are no filtering on the CentOS machine ?
And by the way I don't see ACL 1 used for NAT overload.
Alain
Murad
Please try to change to these commands. they work for me.
ip nat pool testpool Dialer0 Dialer0 prefix-length xxxx
ip nat inside source static tcp 192.168.1.123 22 interface Dialer0 22 extendable
ip nat inside source static tcp 192.168.1.123 21 interface Dialer0 21 extendable
ip nat inside source static tcp 192.168.1.123 20 interface Dialer0 20 extendable
access-list 1 permit 192.168.1.0 0.0.0.255
Murad
Murad
Dont forget to enter below command after " ip nat pool testpool Dialer0 Dialer0 prefix-length xxxx".
ip nat inside source list 1 pool testpool overload
Sorry i forgot to write it down.
Hope it will help.
Murad
Thanks a lot, i do some tests with your suggestions
@cadet-alain
I tested in my LAN network and work it through ssh, but it does not work when i try enter through the Internet.
The ACL was in the config.
@murad-ali
I can't try these comand because the IOS does not suppot it.
This is my IOS version:
Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.3(8)T11, RELEASE SOFTWARE (fc1)
This is my actual config:
Current configuration : 1869 bytes
version 12.3
hostname Router
boot-start-marker
boot-end-marker
no mmi pvc
no aaa new-model
ip subnet-zero
ip cef
no ip address
duplex auto
speed auto
no cdp enable
ip nat inside
duplex auto
speed auto
interface Dialer0
ip mtu 1454
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username xxxxxxxxxxxx password 0 xxxxxx
ip classless
ip http server
dialer-list 1 protocol ip list 1
control-plane
line con 0
password cisco
login
line aux 0
line vty 0 4
password cisco
login
end
Thanks a lot!
Alain
Thank you. That was the reason, NAT Hairpinning. Now I want ask you about some suggestion for the rules NAT to help it work better with FTP. Because when I want to transfer files larger than 10mb connection is lost.
Thanks a lot.
