Problem to access router model 1841
Messias01
I can not access the config menu.
I try access with Serial cable blue DB09 / RJ45 on console port and serial ports on PC using putty or hyperterminal but any connection can not be done. The screen stay black and not show any text.
The computer found the port COM1 but i csn not access any information from Cisco router model 1841
Reza Sharifi
Your post show you are trying to connect to com 3. Can you change it to com 1 and try again?
