Problem to establish ISDN connection between 2 CISCO routers
kongenkoo
I have problem to esteblish conection between CISCO 4000 (12.0) and CISCO 801 (12.1) via ISDN line.
Both routers are configured using "standard working configuration" which we used for remote connection to our customers. But unfortunetely we have problem with last connection.
Configuration of our CISCO 4000 router:
hostname sllh4m
interface BRI0
no ip address
no ip directed-broadcast
encapsulation ppp
dialer pool-member 30
isdn switch-type basic-net3
no fair-queue
no cdp enable
end
interface Dialer2
ip address 10.8.10.102 255.255.255.192
encapsulation ppp
dialer remote-name test801
dialer string 00111222333
dialer load-threshold 100 either
dialer pool 30
dialer-group 2
no fair-queue
no cdp enable
end
And customer CISCO 801 configuration:
hostname test801
interface BRI0
no ip address
encapsulation ppp
interface Dialer2
ip address 10.8.10.101 255.255.255.192
encapsulation ppp
dialer remote-name sllh4m
dialer pool 30
dialer string 09999991
dialer-group 2
no fair-queue
no cdp enable
See attachment for debbug output from our sllh4m router.
5 Replies 5
Kevin Dorrell
Level 10
Level 10
Are you using ppp authentication chap on this connection? I don't see it in the configs, but test801 seems to be requesting it in the LCP. If so, it needs to be configured on the dialer profile interface as welll as on the physical interface on both sides.
Kevin Dorrell
Luxembourg
Hi Kevin,
on both routers there is no CHAP configure. I see that I attached older debbug file when CHAP was configured.
Please see new attachement.
For me the problem is:
BRI:1 LCP: TIMEout: State ACKsent
Martin Kral
Martin,
Are you saying that you have other clients that work correctly with this configuration? If so, maybe there is something I don't understand.
When the called end receives the call, it has to have some information that binds the physical channel into the dialer profile. That is, there must be something on the incoming call that says "I am so-and-so, so this call is part of Dialer n". Usually that is the CHAP username, but it is also possible to do it with the incoming dialed or dialing number if your switchboard provides it. Either way, it has to be configured: ppp authentication chap or dialer caller, or dialer called.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_command_reference_chapter09186a00800c6c62.html#wp1018848
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_command_reference_chapter09186a008008000e.html#wp1120901
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_command_reference_chapter09186a008008000e.html#wp1023505
Kevin.Dorrell
Luxembourg
Kevin,
we're using ppp authentication chap and also I tried it for this customer. But to make troubleshooting easier I removed it because as I know it has to work without authentication.
As I can see Level1 connection is established between routers and on Level2 PPP fails because of LCP is let say down.
Here you can see output from customers router console:
1y16w: %DIALER-6-BIND: Interface BR0:1 bound to profile Di2
1y16w: %LINK-3-UPDOWN: Interface BRI0:1, changed state to up
1y16w: %ISDN-6-CONNECT: Interface BRI0:1 is now connected to 09999991
1y16w: %DIALER-6-UNBIND: Interface BR0:1 unbound from profile Di2
1y16w: %ISDN-6-DISCONNECT: Interface BRI0:1 disconnected from
09999991 , call lasted 24 seconds
1y16w: %LINK-3-UPDOWN: Interface BRI0:1, changed state to down
1y16w: %ISDN-6-LAYER2DOWN: Layer 2 for Interface BR0, TEI 65 changed to
down
Martin,
Sorry, from the configurations you provided in the first posting, I still don't understand how the test801 router is binding the call on Bri0:1 into profile Dialer2. What information is it using to determine that the incoming call pertains to Dialer2?
Authentication usually provides this information as well as validating the caller. However, if you say that it normally works without authentication, then there must be some other information in the call that identifies it as Dialer2.
Perhaps it would be useful to see the full debug on test801 during the call. I'm sure that the called router will tell us more than the calling router.
Kevin Dorrell
Luxembourg
