IOS Question
tteslicko
I currently run this:
"flash:c1700-sv3y-mz.120-5.XQ1"
I need to go to 12.26a version of the same.
We run voice over IP there.
Which one of these will do me right???
Select Software Feature Set
IP/IPX/AT/IBM/VO/FW/IDS PLUS IPSEC 3DES
IP/IPX/AT/IBM/VOICE/FW/IDS PLUS IPSEC 56
IP/IPX/VOICE/FW/IDS PLUS
IP/VOICE PLUS
IP/VOICE PLUS IPSEC 3DES
IP/VOICE PLUS IPSEC 56
IP/VOICE/FW/IDS PLUS
IP/VOICE/FW/IDS PLUS IPSEC 3DES
IP/VOICE/FW/IDS PLUS IPSEC 56
I find the whole IOS way of labeling hard to cross translate at times.
Richard Burts
I agree that the way of labeling IOS is complex and confusing. But it is something that we have to deal with as best we can.
The part of the IOS name that indicates the feature set is the sv3y. Looking through the IOS planner I find that this is the IP/VOICE PLUS feature set. So that is what you should load, assuming that you want to keep the same functionality.
A word of advice, Check the amount of memory and flash required to run the image and the amount you have on the router before you do the upgrade. It looks to me like the minimum is 48 MB of memory and 16 MB of flash.
Rick
Rick
tteslicko
He tony ip/voice plus aughtta do it.
c1700-sv3y-mz.122-26a.bin that XQ thing is probably just code for early release, etc...
were never alone with a scyhzophrenic.....
tteslicko
Thank you my Main Man. I have noted such and will take care. This will be my emergency use device if a long distant NY to CA IOS upgrade over the wan fails me. It will probably be best for the endusers not to swap out routers (interfaces) unless absolutely last resort.But they will have this at their disposal.
The UK is in the same position for us. No outsourcing, or plane ticket,just a makeshift safety net of sorts. Thanks again!!
