Problem updating from 3.x to 16.x on my 4331. unknown image structure
mhdganji110
I'm unsuccessful trying to update my 4331 from 3.x to 16.x and facing this error and booting witht he old one.
Boot image size = 583079197 (0x22c1151d) bytes
Package header rev 3 structure detected
Calculating SHA-1 hash...done
validate_package: SHA-1 hash:
        calculated 595cdb24:b9751f91:731a4622:7034be2b:f11d9c77
        expected   595cdb24:b9751f91:731a4622:7034be2b:f11d9c77
RSA Signed RELEASE Image Signature Verification Successful.
Package Load Test Latency : 10646 msec
Unknown image structure
boot: error executing "boot bootflash:isr4300-universalk9.16.09.01.SPA.bin"
autoboot: boot failed, restarting...
My config is this way:
boot-start-marker
boot system flash bootflash:isr4300-universalk9.16.09.01.SPA.bin
boot system flash bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin
boot-end-marker
Any idea?
2 Accepted Solutions
the syntax looks ok actually. Can you try and upgrade the ROMMON (latest release is isr4200_4300_rommon_169_1r_SPA.pkg) ?
Although the image was copied and verified but I decided to use a different and a little older image:
isr4300-universalk9.16.06.03.SPA.bin
And it was installed and is working properly
Now I'm going to retry installing the first one and will keep everyone informed
6 Replies 6
mesehar
Yes, upgrade the ROMMON and if that does not help too, try downloading the image again.It could be a copy issue.
Leo Laohoo
Upgrade the ROMmon first.
Now the newer IOS-XE is also loaded flawlessly.
The first one had updated ROMMON and so ...
I just can't figure out why the new IOS didn't attempt to upgrade the ROMMON (just like the a-little-older-version IOS did)
Thank you   mhdganji110         I had the same problem    going from 3.16.04  (new box from cisco) to 16.6.4
troubleshot it almost the same way
With your suggestion  I loaded 16.3.7 with no problem, and after the reboot loaded 16.6.4
