Problem while configuring E1
yavuz.ozdemir
I've a router 3725 with a DS3 as main link, now I want to implement a back-up solution via the E1 interface. But when I wanted confiugre my E1 in mode atm aim 1, the traffic has been impacted on the main link, have you an idea why?
I suspect the ATM AIM module which is in slot 1 and the E1 is plugged on slot 0.
sh diag :
Slot 0:
WIC Slot 1:
E1 (2 port)
WIC Slot 2:
E1 (2 port) WAN daughter card
Slot 1:
ATM DS3 Port adapter, 1 port
AIM ATM: 1
ATM AIM
Richard Burts
Yavuz
What you posted does confirm that the E1 is in slot 0 and the DS3 is in slot 1. But that does not help us much to understand what the problem is. Perhaps you could describe the problem a bit more clearly? A good place to start would be to post the configuration of the router.
Rick
Rick
Hi Rick,
Here is the config. of the router when I tried to configure the E1 in ATM MODE, the traffic was impacted on the main link ping success was 60% when I removed the command on the E1 the traffic became ok.
Can you advise me please.
hostname TEST
boot-start-marker
boot-end-marker
logging buffered 50000 debugging
memory-size iomem 10
no network-clock-participate wic 1
no network-clock-participate wic 2
no network-clock-participate aim 1
ip subnet-zero
no ip source-route
ip cef
no ip domain lookup
no ip bootp server
controller E1 0/0
====> I wanted to configure in "mode atm aim 0" the traffic has been impacted.
controller E1 0/1
controller E1 0/2
controller E1 0/3
interface FastEthernet0/0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.80.1 255.255.255.0
ip helper-address 192.168.82.10
duplex auto
speed auto
interface ATM1/0
no ip address
logging event subif-link-status
atm scrambling cell-payload
no atm ilmi-keepalive
pvc 0/5 qsaal
pvc 0/16 ilmi
interface ATM1/0.1 point-to-point
ip address 10.0.32.198 255.255.255.252
pvc 0/334
broadcast
oam-pvc manage
interface ATM1/0.2 point-to-point
ip address 10.30.0.69 255.255.255.252
pvc 0/340
broadcast
oam-pvc manage
interface ATM1/0.3 point-to-point
ip address 10.30.0.73 255.255.255.252
pvc 0/341
broadcast
oam-pvc manage
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 ATM1/0.2
