Problem with 2821 SDRAM KCS-D2800/512
Hi friends,
i put this memory on 2821 router but console give me this error:
SDRAM ECC Error,
err addr - 0x03280000, err data_l 0xFF000000,err data_h 0x00000000,
rcv ecc - 0x00000000, calc ecc 0x24000000, err cnt 0x8A260000
r0 = FFFFFFFF r1 = FFFFFFFF r2 = 0 r3 = 449F0000 r4 = 0
r5 = 38 r6 = 0 r7 = 4025C0D8 r8 = 0 r9 = 20
r10 = FFFFFFFF r11 = FDFDFFFF r12 = 0 r13 = 2000000 r14 = 0
r15 = F4240 r16 = 0 r17 = C100 r18 = 0 r19 = 3400C101
r20 = 0 r21 = 4008ED70 r22 = FFFFFFFF r23 = FFFF00FF r24 = 0
r25 = 4008ED50 r26 = 0 r27 = 45625FF0 r28 = 0 r29 = 45625FEC
r30 = 0 r31 = 45625FE8 r32 = FFFFFFFF r33 = FFFFFFFF r34 = FFFFFFFF
r35 = FFFFFFFF r36 = FFFFFFFF r37 = FFFFFFFF r38 = FFFFFFFF r39 = FFFFFFFF
r40 = FFFFFFFF r41 = FFFFFFFF r42 = FFFFFFFF r43 = FFFFFFFF r44 = FFFFFFFF
r45 = FFFFFFFF r46 = FFFFFFFF r47 = FFFFFFFF r48 = 0 r49 = D0D0D0D
r50 = 0 r51 = 0 r52 = 0 r53 = 3040A801 r54 = FFFFFFFF
r55 = A000F000 r56 = FFFFFFFF r57 = FFFFFFFF r58 = FFFFFFFF r59 = 8000EDB0
r60 = FFFFFFFF r61 = FFFFFFFF r62 = 0 r63 = 4009DE68
sreg = 3400C103 mdlo_hi = 0 mdlo = 3E8
mdhi_hi = 0 mdhi = 0 badvaddr_hi = FFFFFFFF
badvaddr = FFFFFFFF cause = FFFFFFFF epc_hi = 0
epc = 4008E830 err_epc_hi = FFFFFFFF err_epc = FFFFFFFF
%ERR-1-FATAL: Fatal error interrupt, reloading
err_stat=0x0
I think that this RAM is failed or not compatible. What do you think about it? Can you give me an answer? thanks
ankbhasi
Hi Friend,
The "SDRAM ECC Error" means that there was checksum error in the memory, a parity error.
Usually parity errors are transient issue but when repeated this indicates a HW failure.
It looks its a bad RAM tat you had.
Ankur
*Pls rate all helpfull post
thanks!
