Problem with 3650 stack
rico.nego.rico.nego
Community Member
I try to add a new member to existing stack and I can’t because on the a new member  at the console I can see log
STACKMGR-1-RELOAD: Reloading due to reason active removed before switch became ready.
What does “Reloading due to reason active removed before switch became ready” mean?
Booting...Initializing RAM +++++++@@@@@@@@...++++++++++++++++++++++++++++++++@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@done.
Memory Test Pass!
Base ethernet MAC Address: 64:f6:9d:62:ea:00
Interface GE 0 link down***ERROR: PHY link is down
Initializing Flash...
flashfs[7]: 0 files, 1 directories
flashfs[7]: 0 orphaned files, 0 orphaned directories
flashfs[7]: Total bytes: 6784000
flashfs[7]: Bytes used: 1024
flashfs[7]: Bytes available: 6782976
flashfs[7]: flashfs fsck took 1 seconds....done Initializing Flash.
Getting rest of image
Reading full image into memory....done
Reading full base package into memory...: done = 82657092
Nova Bundle Image
Kernel Address    : 0x6042d34c
Kernel Size       : 0x418331/4293425
Initramfs Address : 0x60845680
Initramfs Size    : 0xe780c1/15171777
Compression Format: .mzip
Bootable image at @ ram:0x6042d34c
Bootable image segment 0 address range [0x81100000, 0x82140000] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 377
Loading Linux kernel with entry point 0x8166a500 ...
Bootloader: Done loading app on core_mask: 0xf
### Launching Linux Kernel (flags = 0x5)
All packages are Digitally Signed
Starting System Services
FIPS(NGWC): Flash Key Check : Begin
FIPS(NGWC): Flash Key Check : End, Not Found, FIPS Mode Not Enabled
May 4 04:33:06 %STACKMGR-1-STACK_LINK_CHANGE: Stack port 2 on switch 1 is up
May 4 04:33:12 %STACKMGR-1-RELOAD: Reloading due to reason active removed before switch became ready
May 4 04:33:12 %IOSXE-3-PLATFORM: process sysmgr: Reset/Reload requested by [stack-manager].
<Thu May  4 04:33:12 2017> Message from sysmgr: Reason Code:[4] Reset Reason:Reset/Reload requested by [stack-manager]. [active removed before switch became ready]
get_local: failed: No such file or directory
Unmounting ng3k filesystems...
Unmounted /dev/sda3...
Warning! - some ng3k filesystems may not have unmounted cleanly...
Please stand by while rebooting the system...
Restarting system.
Nova Bundle Image
May 4 04:37:48 %STACKMGR-1-STACK_LINK_CHANGE: Stack port 2 on switch 1 is up
May 4 04:37:54 %STACKMGR-1-RELOAD: Reloading due to reason active removed before switch became ready
May 4 04:37:54 %IOSXE-3-PLATFORM: process sysmgr: Reset/Reload requested by [stack-manager].
<Thu May  4 04:37:54 2017> Message from sysmgr: Reason Code:[4] Reset Reason:Reset/Reload requested by [stack-manager]. [active removed before switch became ready]
Restarting system.
Nova Bundle Image
May 4 04:42:35 %STACKMGR-1-STACK_LINK_CHANGE: Stack port 2 on switch 2 is up
May 4 04:42:42 %STACKMGR-1-RELOAD: Reloading due to reason active removed before switch became ready
May 4 04:42:43 %IOSXE-3-PLATFORM: process sysmgr: Reset/Reload requested by [stack-manager].
<Thu May  4 04:42:43 2017> Message from sysmgr: Reason Code:[4] Reset Reason:Reset/Reload requested by [stack-manager]. [active removed before switch became ready]
  1. Break the stack.
  2. Break into ROMmon.
  3. Format the flash:
  4. Re-install the IOS using the Emergency Recovery proceedure.
  5. Once the IOS has been installed correctly, power down the switch, install the stacking cable and power up the switch.
5 Replies 5
Leo Laohoo
Pull the power to the new stack member and leave it off for about 5 seconds and then plug it back in.
I did as you suggested but unfortunately the problem is the same.
  1. Break the stack.
i did as you wrote and It works. I'm very grateful for your help.
Thank you very much for taking the time to rate our posts.  🙂
