Problem with, 888G-w PCEX-HSPA-G
olivier_yts
Hi guys,
I have configured a 881G with PCEX-HSPA-G module and the Cellular interface never comes up
Im having some trouble to connect to internet
i've tried several tuto
I have attached my current config. Please help
Note : By cellular interface coming Up, I meant that Amber LED on the module will continously blinkin which indicates that the connection has not been established.
Current configuration : 2135 bytes
version 12.4
no service pad
hostname Router
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5 $1$KVca$yQkmfTdqZnN1QEpa5u6l21
enable password user
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ip source-route
no ip routing
ip dhcp excluded-address 10.10.10.1
ip dhcp pool ccp-pool
   import all
   network 10.10.10.0 255.255.255.248
   default-router 10.10.10.1
   lease 0 2
no ip cef
no ipv6 cef
chat-script gsm "" "ATDT*98*1#" TIMEOUT 60 "CONNECT"
username user privilege 15 secret 5 $1$x0oX$Edap7gNKRSoEUmXaEOSAI.
archive
log config
  hidekeys
controller DSL 0
interface FastEthernet0
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface wlan-ap0
description Service module interface to manage the embedded AP
no ip address
no ip route-cache
arp timeout 0
interface Wlan-GigabitEthernet0
description Internal switch interface connecting to the embedded AP
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly
encapsulation ppp
no ip route-cache
dialer in-band
dialer idle-timeout 30
dialer string gsm
dialer-group 1
async mode interactive
ppp ipcp dns request
interface Vlan1
ip address 10.10.10.1 255.255.255.248
ip nat inside
no ip route-cache
ip tcp adjust-mss 1452
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Cellular0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0 overload
access-list 1 permit any
dialer-list 1 protocol ip list 1
snmp-server community user RO
control-plane
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line 3
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
transport input all
line vty 0 4
password user
login
scheduler max-task-time 5000
end
Tagir Temirgaliyev
probably you need to configure cellular profile
write here
sh cell 0 all
This is my cell info in my profile my provider said there's no need for username and password only an APN
Hardware Information
Modem Firmware Version = F1_2_3_22AP C:/WS/F
Modem Firmware built = 06/22/09
Hardware Version = 1.1
International Mobile Subscriber Identity (IMSI) = 547200104562450
International Mobile Equipment Identity (IMEI) = 356812011866686
Factory Serial Number (FSN) = D46062012241144
Modem Status = Online
Current Modem Temperature = 26 deg C, State = Normal
Profile Information
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) = internet
Authentication = None
Username: , Password:
* - Default profile
Data Connection Information
Data Transmitted = 0 bytes, Received = 0 bytes
Profile 1, Packet Session Status = INACTIVE
        Inactivity Reason = Normal inactivate state
Profile 2, Packet Session Status = INACTIVE
Profile 3, Packet Session Status = INACTIVE
Profile 4, Packet Session Status = INACTIVE
Profile 5, Packet Session Status = INACTIVE
Profile 6, Packet Session Status = INACTIVE
Profile 7, Packet Session Status = INACTIVE
Profile 8, Packet Session Status = INACTIVE
Profile 9, Packet Session Status = INACTIVE
Profile 10, Packet Session Status = INACTIVE
Profile 11, Packet Session Status = INACTIVE
Profile 12, Packet Session Status = INACTIVE
Profile 13, Packet Session Status = INACTIVE
Profile 14, Packet Session Status = INACTIVE
Profile 15, Packet Session Status = INACTIVE
Profile 16, Packet Session Status = INACTIVE
Network Information
Current Service Status = Normal, Service Error = None
Current Service = Combined
Packet Service = Unknown (Attached)
Packet Session Status = Inactive
Current Roaming Status = Home
Network Selection Mode = Automatic
Country = PYF, Network = VINI
Mobile Country Code (MCC) = 547
Mobile Network Code (MNC) = 20
Location Area Code (LAC) = 100
Routing Area Code (RAC) = 1
Cell ID = 10333
Primary Scrambling Code = 137
PLMN Selection = Automatic
Registered PLMN = F-VINI , Abbreviated = VINI
Service Provider =
Radio Information
Current Band = WCDMA 2100, Channel Number = 10836
Current RSSI = -72 dBm
Band Selected = Auto
Number of nearby cells = 1
Cell 1
        Primary Scrambling Code = 0x89
        RSCP = -74 dBm, ECIO = -4 dBm
Modem Security Information
Card Holder Verification (CHV1) = Disabled
SIM Status = OK
SIM User Operation Required = None
Number of Retries remaining = 3
hi everybody,
i solved my problem
Because the network is not authenticating itself to you, the connection fails.
You need to configure the router to trust the network and not ask for CHAP authentication "
and adviced to add below commands:
interface Cellular0
ppp chap refuse
So, at the end correct config is below:
interface Cellular0
ip nat outside
ip virtual-reassembly in
encapsulation ppp
dialer in-band
dialer idle-timeout 0
dialer string gsm
dialer-group 1
ppp chap refuse
its not really related with the title of the topic.
