Problem with a Cisco Switch 4948
fernando.ortega
Hi guys,
The device show me this logs:
Oct 11 10:13:29.254 BOGOTA: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId0 on Switch Phyport Gi1/32, count=9986879
Oct 11 10:13:29.254 BOGOTA: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId1 on Switch Phyport Gi1/32, count=9986989
Oct 11 10:13:29.254 BOGOTA: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId3 on Switch Phyport Gi1/32, count=9986989
Oct 11 10:23:31.741 BOGOTA: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId0 on Switch Phyport Gi1/32, count=9986992
Oct 11 10:23:31.741 BOGOTA: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId1 on Switch Phyport Gi1/32, count=9987102
Oct 11 10:23:31.741 BOGOTA: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId3 on Switch Phyport Gi1/32, count=9987102
Oct 11 10:33:32.212 BOGOTA: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId0 on Switch Phyport Gi1/32, count=9987105
Oct 11 10:33:32.212 BOGOTA: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId1 on Switch Phyport Gi1/32, count=9987215
Oct 11 10:33:32.212 BOGOTA: %C4K_HWPORTMAN-4-BLOCKEDTXQUEUE: Blocked transmit queue HwTxQId3 on Switch Phyport Gi1/32, count=9987215
But the state of a port is:
interface GigabitEthernet1/32
switchport mode access
switchport port-security
shutdown
no cdp enable
The software version is: Version 12.2(20)EWA4, RELEASE SOFTWARE (fc2)
The IOS is: "bootflash:cat4000-i9k91s-mz.122-20.EWA4.bin"
Thanks...
Gabrriel
I dont know which is the reason for it.
5 Replies 5
Jerry Ye
You are hitting bug id CSCsb01311 (the fix is in 12.2(25)SG or later) and you are running very old software. It is time to upgrade.
jerry
Hi jeye...
But, i dont understand...
This bug applies even though the state of the port is administratively down?
Gabriel
Yes it does.
Hi again,
What is the image that is recommended?
Since the Bug displayed are unclear.
Thanks for your responses.
Gabriel
Choose a new/higher version IOS of your liking and read the Release Notes.  If you believe that you're not hitting a known bug, then implement it.
