problem with a e1/t1 card
Osman_gadji_2
Community Member
Hello all.
Please help me.
I have a Cisco 2821 Router (c2800nm-ipbase-mz.124-15.T12.bin) with a HWIC-2T and HWIC-2CE1T1-PRI.
My device is can not see the HWIC-2CE1T1-PRI in IOS
But at the start i see next message:
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
  ID                MEMORY_REQ                 TYPE
0003E8          0X00473800 C2821 Mainboard
00052A          0X001E6800 2 port channelized and PRI T1/E1 HWIC
                     0X00264050 Onboard VPN
                     0X000021B8 Onboard USB
                     0X002C29F0 public buffer pools
                     0X00211000 public particle pools
TOTAL:          0X00D93BF8
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 14Mb.
Using 2 percent iomem. [14Mb/512Mb]
In the show run command, i can not see my HWIC-2CE1T1-PRI card, but it setuped in HWIC1 Slot.
Router#show ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(22)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 10-Oct-08 00:05 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T11, RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes
System image file is "flash:c2800nm-advipservicesk9-mz.124-22.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2821 (revision 53.50) with 509952K/14336K bytes of memory.
Processor board ID FCZ1420724J
2 Gigabit Ethernet interfaces
2 Serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
126000K bytes of ATA CompactFlash (Read/Write)
What to do next?
krahmani323
Level 9
Level 9
Hi Osman,
Is your IOS c2800nm-ipbase-mz.124-15.T12.bin or c2800nm-advipservicesk9-mz.124-22.T.bin ?
If your IOS is 124-15.T12 :
From http://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88_ps5949_Products_Data_Sheet.html check :
Table 2. Minimum Cisco IOS Software Requirements
1800, 2800, and 3800 Series
1900, 2900, and 3925, 3945
Cisco 3925E, 3945E
Minimum IOS Release
12.4(20)T
15.0(1)M
15.1(1)T
Minimum IOS Technology Package
IP Base
IP Base
IP Base
Can you upgrade your IOS to at least 12.4(20)T and let us know ?
Thanks and Regards.
Karim
krahmani323
Level 9
Level 9
Hi Osman,
Cisco 3925E, 3945E
Minimum IOS Release
12.4(20)T
15.0(1)M
15.1(1)T
IP Base
IP Base
IP Base
Thanks and Regards.
Karim
Sorry, I made a mistake.
My image of the IOS is c2800nm-advipservicesk9-mz.124-22.T.bin
Can you post a 'show run' and 'show diag'
Osman_gadji_2
Community Member
Excuse me guys
I have not read it here
http://www.cisco.com/en/US/docs/ios/12_3/vvf_r/vrg_c2_ps1839_TSD_Products_Command_Reference_Chapter.html#wp1124401
This https://supportforums.cisco.com/message/796136 post is similar to my problem
Everything works, no problem.
Once again, sorry
Thank you all.
