10-25-2007 10:16 PM - edited 03-03-2019 07:21 PM
I have some problems with a route after changing network address, that's why I don't know how to do it. Our e-mail server dosn't see any icmp parkets after their intf. For expl.
192.168.2.2
I think this line it's not correct
ip route Ñ .Ñ .Ñ .90 255.255.255.255 192.168.2.1
ip route Ñ .Ñ .Ñ .91 255.255.255.255 192.168.2.1
ip route 192.168.2.0 255.255.255.0 192.168.2.1 permanent
Here's the whole config:
boot-start-marker
boot-end-marker
username Ñ Ñ Ñ Ñ password 7 Ñ Ñ Ñ Ñ Ñ Ñ Ñ Ñ Ñ Ñ Ñ Ñ Ñ Ñ
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
aaa new-model
aaa authentication ppp default local
aaa authorization network default local
aaa session-id common
ip subnet-zero
ip cef
ip flow-cache timeout active 1
no ip domain lookup
vpdn enable
vpdn source-ip Ñ .Ñ .Ñ .94
vpdn-group 1
accept-dialin
protocol l2f
virtual-template 1
terminate-from hostname Ñ Ñ Ñ Ñ
local name Ñ Ñ Ñ Ñ .ru
no ftp-server write-enable
interface Ethernet0
description inet
ip address Ñ .Ñ .Ñ .94 255.255.255.248
ip nat outside
ip route-cache flow
full-duplex
interface FastEthernet0
description xxx
ip address 192.168.2.2 255.255.255.252
ip nat inside
ip route-cache flow
speed auto
full-duplex
interface Virtual-Template1
ip unnumbered Ethernet0
no ip proxy-arp
peer default ip address pool Ñ Ñ Ñ Ñ Ñ _pool
ppp authentication pap chap
router rip
version 2
network 192.168.2.0
no auto-summary
ip local pool Ñ Ñ Ñ Ñ _pool 192.168.2.65 192.168.2.94
ip nat inside source list 1 interface Ethernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Ñ .Ñ .Ñ .89 permanent
ip flow-export source Ethernet0
ip flow-export version 5
ip flow-export destination 172.Ñ .Ñ .Ñ 9996
no ip http server
11-01-2007 06:46 AM
I see the line ip route 0.0.0.0 0.0.0.0 x.x.x.89 permanent above all routing lines. Put this line at last after having configured all the specific routes for example after the line ip route 192.168.2.0 255.255.255.0 192.168.2.1 permanent
