Bookmark
Subscribe
501
Problem with a topology on OSPF mutliarea protocol
I have to do the following topology on packet tracer, I use the student edition:
topologytopology
I read the ospf protocol with mutli areas and I understand many things. But first I can't do the above topology on packet tracer, when I statically make the ip route from R2 to R4 I can't pint to it. I use copper-straight-through and the HWIC-4ESW to extend the ethernet ports to R2. Any suggestion?
For example I give from R2:
#enable
#configure terminal
#interface f0/1
#ip address 172.16.32.1 255.255.255.0
#no shutdown
#exit
and from R4 the below:
#enable
#configure terminal
#interface f0/0
#ip address 172.16.32.2 255.255.255.0
#no shutdown
#exit
And can't connect (get red signals on the wire).
Also can anyone explain me how make summarization on R2,R3,R4,R5?  What instructions do I have to complete?  Thanks in advance!!!
Martin L
Do not use HWIC-4ESW; that is a switching module for connecting PCs like a L2 switch inside of a router. HWIC-4ESW uses interface vlan x to communicate.
if u need ports, add fiber ports Or use 2811 router and add module with 2 fast Ethernet ports
Mulitarea OSPF in PT works but it is not accurate as real routers.
you can zip your PT file and attach here. must be a zip file to be able to attach here
Regards, ML
**Please Rate All Helpful Responses **
