Problem with BGP backdoor
nick-moore
Good evening.  I am working on a bgp routing issue and decided that using the backdoor switch to make my router prefer my eigrp route over bgp would make routing this particular set of networks more efficient.  So, here is the problem:  I am advertising vpn client routes from my firewall at the time they connect.  These are 192.168.251.x /32 routes.  This works very well.  However, in this one site, I need to force the eigrp route to be chosen over bgp.  My config looks like this:
router bgp 65017
bgp log-neighbor-changes
timers bgp 15 45
neighbor 10.x.x.x remote-as 1850
address-family ipv4
 network 10.x.x.x mask 255.255.252.0
 network 192.168.251.0 mask 255.255.255.0 backdoor
 neighbor 10.x.x.x activate
 etc.
This does not work.  The 192.168.251.x /32 route remains ebgp with an ad of 20.
When I change the network statement to: network 192.168.251.134 255.255.255.255 backdoor, it DOES work.  The eigrp ex route is added to the routing table with the ad of 170.
So, is there a way to fix this without adding 255 network...backdoor statements?  I've tried configuring route-maps in combination with the network....backdoor statement, but no luck.
The issue is obviously related to matching the prefix and mask, but this puzzle should have a solution.  Any ideas?
Hello
 Simplistic solution would be to aggregate that ip range then backdoor on the received aggregate.
RTRx
router bgp xx
aggregate-address 192.168.251.0 255.255.255.0 summary-only
RTRy
Kind Regards
Paul
18 Replies 18
Is the /24 route actually in the routing table ? If not, try and add a null route for the /24 network...
I do not see a /24 supernet in the routing table. This is what these routes look like in the table.
[cid:image001.png@01D47745.24620780]
Sorry, the graphic doesn't come through.
192.168.251.0/32 is subnetted, 37 subnets
B 192.168.251.2 [20/0] via 10.250.250.86, 06:14:54
B 192.168.251.107 [20/0] via 10.250.250.86, 06:14:54
B 192.168.251.115 [20/0] via 10.250.250.86, 06:14:54
B 192.168.251.123 [20/0] via 10.250.250.86, 06:14:54
B 192.168.251.132 [20/0] via 10.250.250.86, 06:14:54
B 192.168.251.133 [20/0] via 10.250.250.86, 06:14:54
B 192.168.251.140 [20/0] via 10.250.250.86, 06:14:54
B 192.168.251.144 [20/0] via 10.250.250.86, 06:14:54
B 192.168.251.145 [20/0] via 10.250.250.86, 02:12:33
B 192.168.251.146 [20/0] via 10.250.250.86, 03:38:24
B 192.168.251.147 [20/0] via 10.250.250.86, 02:04:47
B 192.168.251.148 [20/0] via 10.250.250.86, 01:58:18
B 192.168.251.150 [20/0] via 10.250.250.86, 01:34:38
B 192.168.251.151 [20/0] via 10.250.250.86, 01:30:51
B 192.168.251.152 [20/0] via 10.250.250.86, 01:18:40
add the static null route below:
ip route 192.168.251.0 255.255.255 null 0
No luck with adding the null route. I added the following:
ip route 192.168.251.0 255.255.255.0 Null0
And now my routing table looks like this:
192.168.251.0/24 is variably subnetted, 43 subnets, 2 masks
S 192.168.251.0/24 is directly connected, Null0
B 192.168.251.2/32 [20/0] via 10.250.250.86, 07:29:45
B 192.168.251.107/32 [20/0] via 10.250.250.86, 07:29:45
B 192.168.251.115/32 [20/0] via 10.250.250.86, 07:29:45
B 192.168.251.123/32 [20/0] via 10.250.250.86, 07:29:45
B 192.168.251.132/32 [20/0] via 10.250.250.86, 07:29:45
B 192.168.251.133/32 [20/0] via 10.250.250.86, 00:01:32
B 192.168.251.140/32 [20/0] via 10.250.250.86, 07:29:45
B 192.168.251.144/32 [20/0] via 10.250.250.86, 00:59:03
B 192.168.251.145/32 [20/0] via 10.250.250.86, 00:49:31
B 192.168.251.146/32 [20/0] via 10.250.250.86, 04:53:15
B 192.168.251.147/32 [20/0] via 10.250.250.86, 03:19:38
B 192.168.251.148/32 [20/0] via 10.250.250.86, 03:13:09
B 192.168.251.149/32 [20/0] via 10.250.250.86, 00:34:13
B 192.168.251.150/32 [20/0] via 10.250.250.86, 02:49:29
B 192.168.251.151/32 [20/0] via 10.250.250.86, 02:45:42
I cleared one of the above /32 routes and it immediately repopulated as ebgp ad 20
This is my backdoor statement:
Hello
RTRx
router bgp xx
RTRy
Kind Regards
Paul
Interesting. I tried the aggregate-address statement in my datacenter router and it then the network...backdoor statement on this branch router does add a backdoor eigrp route, but the more specific 192.168.251.x/32 ebgp routes still exist as well. Here is the routing table after setting this config:
192.168.251.0/24 is variably subnetted, 42 subnets, 2 masks
D EX 192.168.251.0/24
[170/41984] via 192.168.77.17, 00:02:08, GigabitEthernet0/2
B 192.168.251.2/32 [20/0] via 10.250.250.86, 10:48:09
B 192.168.251.107/32 [20/0] via 10.250.250.86, 00:00:49
B 192.168.251.115/32 [20/0] via 10.250.250.86, 01:45:34
B 192.168.251.123/32 [20/0] via 10.250.250.86, 10:48:09
B 192.168.251.132/32 [20/0] via 10.250.250.86, 10:48:09
B 192.168.251.133/32 [20/0] via 10.250.250.86, 03:14:34
B 192.168.251.140/32 [20/0] via 10.250.250.86, 10:48:09
B 192.168.251.144/32 [20/0] via 10.250.250.86, 04:17:27
Hello
did you include  Summary Only
Kind Regards
Paul
I cleared the bgp peer and the bgp route aggregation that Paul suggested worked.  Thanks much.  I appreciate the help.
@Georg Pauwen this wont work it will just blackhole traffic not active
Kind Regards
Paul
I tried adding the static null /32 route and it did not resolve my problem.
can't you just run the VPN client routes under a different EIGRP process and then redistribute with a lower metric (19) ? That said, how do you currently redistribute EIGRP and BGP ?
I use rri to advertise the vpn routes into the eigrp process in my datacenter and at my datacenter router, I do mutual redistribution between eigrp and bgp.
here is what I mean:
router eigrp 1
distance 19 192.168.12.2 0.0.0.0 <-- this is your EIGRP neighbor
or
distance eigrp 19 19 <-- this sets the AD to 19 for both internal and external routes
router bgp 1
bgp router-id 1.1.1.1
redistribute eigrp 1
This will result in the redistributed routes to have an AD of 19, so you won't even need the backdoor.
