Problem with Cisco 887VA
asadmaqsood
I am facing a problem with Cisco 887VA, it has been bought for DMVPN use but as this router has advance Security (router eigrp) command is not support as it was not supported in Cisco 877 so I upgarded Cisco 887VA to (c880data-universalk9-mz.124-22.YB8.bin) image but now when router restart it says
Wrong IOS image for the router
System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
C880 platform with 262144 Kbytes of main memory
Readonly ROMMON initialized
and it keeps on restarting n restarting
So wht shall I do to upgarde this router with an advance IP IOS to use (router eigrp) command.
3 Accepted Solutions
Seb Rupik
Hi Asad,
Looks like you will need to load a correct IOS verison into flash. Since you don't have removable flash on a 887, you will need to access ROMMON.
Follow the instructions here:
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon.html#wp1027195
...then either use TFTP to download an image to the router:
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon.html#wp1070700
...or use the xmodem method:
http://www.cisco.com/en/US/docs/routers/access/1800/1841/software/configuration/guide/b_rommon.html#wp1044991
If you choose the xmodem method remember you will be limited by the conosle baud rate (9600), so it may be worth setting it to something higher. Only do this if you are happy to modifiy the config-register settings though!
Let us know if you get stuck on any of the above steps.
cheers,
Seb.
you should have a USB port on these routers where you can plug a USB key(FAT32) with a valid IOS on it.
You could then use the boot command to boot from the USB key then you'll be able to delete the old ios on flash and copy the newest one.
Alain
use the boot system command to boot from USB key(save config) then delete the old IOS and copy newest one on flash with tftp or any other protocol of your choice.unplug USB key and reload and it should boot from flash then delete your boot system command(save config) and you should be ok provided you have enough flash and memory needed for newest IOS.
Alain
18 Replies 18
Seb Rupik
Hi Asad,
cheers,
Seb.
jawad-mukhtar
Level 4
Level 4
It seems u deleted iOS please follow procedure documented on Cisco site always try to upgrade iOS through normal mode
Sent from Cisco Technical Support Android App
Jawad
Thank you Seb Rupik and Jawad Mukhtar
Router has been recovered on (c880data-universalk9-mz.153-3.M.bin)
but still I cant find router eigrp command in this IOS is there a way that I can upgarde it to advanced IP IOS of Cisco 887
Hi Asad,
Glad to hear you got it recovered!
To gain access to IOS images the easiest method is via a SmartNet contract for your device with Cisco. Unfortunately you can no longer download them yourself from Cisco.
cheers,
Seb.
jawad-mukhtar
Level 4
Level 4
U need a lic to activate that feature adv IP services or enterprise from cco account that need smart net privileges
Jawad
After restart Router goes in rommon mode again
and I followed same process to re do IOS from TFTP
now it gives this
TFTP: Error, insufficient flash installed to load image.
TFTP: Operation terminated.
now whats wrong in it
What is the config register set to? Can you post a sh ver? I suspect it is not set to 0x2102
If it isn't set to 0x2102 at rommong ouse the following command and reload the router
rommon  > confreg 0x2102
You've run out of space on the flash memory.
Delete your previous 'c880data-universalk9-mz.153-3.M.bin' image and restart the TFTP download again.
cheers,
Seb.
Hi Seb Rupik
Ya flash memory space is went out but in rommon mode there is no command to del or format flash, if it del or format than IOS can be downloaded form TFTP but question is how to del that
Hi Asad,
If you can boot into IOS why not delte the .bin file from there:
delete flash:/c880data-universalk9-mz.153-3.M.bin
...and then load your new image via TFTP:
copy tftp flash
...since you only have one IOS image the router should load it once you issue the reload command. You can set the boot var. Check that boot var has been set:
show bootvar
...it should print out sometihng like:
BOOT variable = flash:c880data-universalk9-mz.153-3.M.bin
So try:
conf t
no boot system image flash:c880data-universalk9-mz.153-3.M.bin
exit
wr mem
reload
cheers,
Seb.
Hi Seb Rupik
Register value is ok but actually when router start it shows me wrong IOS for this router and when I go in rommon it doesnt pick up new bin file from tftp coz of insufficient space in flash.
To del or format flash these commands r not available in rommon mode if it does I have done this long time.
Is there n e other way.
Alain
Hi Cadet Alain
I will try this and come back to you. Thank you
HI Cadet Alain
Router has been recovered by this process to its original IOS but still I want to upgarde this on advanced ip service IOS
HOW TO DO THAT
