Problem with Cisco 887VA
asadmaqsood
I am facing a problem with Cisco 887VA, it has been bought for DMVPN use but as this router has advance Security (router eigrp) command is not support as it was not supported in Cisco 877 so I upgarded Cisco 887VA to (c880data-universalk9-mz.124-22.YB8.bin) image but now when router restart it says
Wrong IOS image for the router
System Bootstrap, Version 12.4(22r)YB5, RELEASE SOFTWARE (fc1)
Copyright (c) 2009 by cisco Systems, Inc.
C880 platform with 262144 Kbytes of main memory
Readonly ROMMON initialized
and it keeps on restarting n restarting
So wht shall I do to upgarde this router with an advance IP IOS to use (router eigrp) command.
18 Replies 18
use the boot system command to boot from USB key(save config) then delete the old IOS and copy newest one on flash with tftp or any other protocol of your choice.unplug USB key and reload and it should boot from flash then delete your boot system command(save config) and you should be ok provided you have enough flash and memory needed for newest IOS.
Alain
Hi Alain
I did this and copied newset of IOS that is available on cisco support website but all these newset IOS are advanced secuirty not the advanced ip service all I need to know how can i upgarde on advance ip service from advanced secuirty.
Post the output to the command "sh license".
Hi Leo
Index 1 Feature: advipservices
        Period left: Not Activated
        Period Used: 0  minute  0  second
        License Type: EvalRightToUse
        License State: Not in Use, EULA not accepted
        License Count: Non-Counted
        License Priority: None
Index 2 Feature: advsecurity
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Index 3 Feature: ios-ips-update
