Problem with csr1000v booting and startup console using gns3 in windows 10 environment and VirtualBOX oracle.
samya.ghosh
Dear All,
I am facing  problem to open consol of csr1000v from gns3 , i am using virtualbox from oracle.
each time i get the error like ...
Prentinue.
Press any key to continue.
    GNU GRUB  version 0.97  (639K lower / 2071488K upper memory)
| CSR1000v - packages.conf                                                |
| CSR1000v - GOLDEN IMAGE                                                 |
      Use the ^ and v keys to select which entry is highlighted.
      Press enter to boot the selected OS, or 'c' for a command-line.
  Booting 'CSR1000v - GOLDEN IMAGE'
root (hd0,4)
Filesystem type is ext2fs, partition type 0x83
kernel /csr1000v-universalk9.03.10.02.S.153-3.S2-ext.SPA.bin rw quiet root=/dev
/ram console= max_loop=64 HARDWARE=virtual VMCONSOLE SR_BOOT=bootflash:csr1000v
package header rev 1 structure detected
Calculating SHA-1 hash...done
SHA-1 hash:
        calculated   f97a077b:41740cf5:bdb2962d:9e6bb3e2:1caadaa4
        expected     f97a077b:41740cf5:bdb2962d:9e6bb3e2:1caadaa4
Package type:0x7530, flags:0x0
   [Linux-bzImage, setup=0x2e00, size=0x103bb660]
   [isord @ 0x6f85c000, 0xef84000 bytes]
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (local/local): start_udev took: 59 seconds, expected max time 10 seconds
%IOSXEBOOT-4-BOOT_ACTIVITY_LONG_TIME: (local/local): start_udev_and_read_cmdline took: 11 seconds, expected ma                                               x time 10 seconds
%IOSXEBOOT-4-EUSB_PROVISIONING: (rp/0): Unsupported low capacity eUSB detected in VXE board
It will be great help for me and lot of others if any-one have some solutions for it.
Thanks in advance
Samya
keglass
Level 7
Level 7
Samya,
I recommend you also post this to the Cisco Support Community for more feedback and information from technical experts.
https://supportforums.cisco.com/
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
