Problem With Gbic Fiber in sfp module
pedram rabeti
Hi ,
I have Fiber Uplink port and want to connect in SFP port ( 2960 ) with Gbic connector . But Port on which the fiber is attached is down.
I used the other switch with SFP module ( Planet switch ) for testing fiber links , its  working properly .
I have bypass bandwith with externded switch (planet) to convert fiber link to ethernet and connect One of the pors to cisco switch .
Please help me to up my SFP port on cisco 2960 switch and remove Addition switch (Planet switch ).
2 Accepted Solutions
I think you have an OM1 fibre optic link.
Have you ever seen this link :
http://www.cisco.com/en/US/products/hw/modules/ps4999/products_tech_note09186a00807a30d6.shtml
which is introduced this type of module. Also this link :
https://supportforums.cisco.com/thread/2038428
which is discussed a little bit more in depth.
As you guessed it could becasue of some mismatch configuration and need to check your provider side too.
15 Replies 15
Leo Laohoo
What is the model number of the SFP module you are using on the 2960?
Hi ,
Prod.# : GLC-SX-MM    Cisco Malaysia
P/N : 30-1301-02
Regard
On the Cisco switch, can you post the output to the command "sh interface "?
yes here output command : sh interface :
2960#show interfaces gigabitEthernet 0/21
GigabitEthernet0/21 is down, line protocol is down (notconnect)
  Hardware is Gigabit Ethernet, address is d4a0.2a6b.d315 (bia d4a0.2a6b.d315)
  Description: Fiber
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
  Keepalive not set
  Auto-duplex, Auto-speed, link type is auto, media type is 1000BaseSX SFP
  input flow-control is off, output flow-control is unsupported
  Last input never, output 03:41:20, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     943 packets input, 172371 bytes, 0 no buffer
     Received 943 broadcasts (538 multicasts)
     0 watchdog, 538 multicast, 0 pause input
     117 packets output, 25664 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
Maybe the ends are the other way around.
How far is the other end?
Not far ,  about 300 meter
What is the exact distance?
GLC-SX-MM can reach 300 metre if your fibre optic link is OM2.
Read Cisco Small Form-Factor Pluggable Modules for Gigabit Ethernet Applications Data Sheet and refer to Table 1.
The exact distance is 270 meter . But this link on planet switch with this Gbic is working properly.
Have you tried by issuing 'speed nonegotiate' SFP ?(or both ends?)
Thx
MS
Hi ,
The speed mode not change when SFP module attached in switch .
Thank you
Hi Leo
Thank you for replay
This link will operate properly in the past ( on 2960 ) . We did not have a problem until it was changed by provider .
provider change other side router .
My optic link not changed in 5 past years and this link work with other switch . I think I need to change parameter on intherface. (Fiber)
Regard
Hi Hesam ,
Thanks for posting links . Cisco switch just work with CISCO SFP . I Think SFP attached  in other side of my Fiber link  is not cisco SFP .i should be call with provider and check other side SFP.
I am waiting for your comments
Best Regard
