Problem with ip nat inside source static
marianares0001
Level 2
Level 2
I need to open a port in a Cisco 2911 router to permit the conexion to an equipment that is inside the LAN, but I my configuration doesn't workt.
I have 3 interfaces configured: two WAN interfaces (one is a backup of the other) and a LAN interface. The configuration is this (public IPs are changed):
track 1 ip sla 1 reachability
interface GigabitEthernet0/0
description backup
ip address 176.55.25.25 255.255.255.252
ip nat outside
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/1
description primary
ip address 192.168.2.2 255.255.255.252
ip nat outside
load-interval 30
duplex auto
speed auto
interface Vlan1
description LAN segment
ip nat inside
load-interval 30
ip forward-protocol nd
ip nat inside source route-map backup interface GigabitEthernet0/0 overload
ip nat inside source route-map primary interface GigabitEthernet0/1 overload
ip nat inside source static udp 192.168.1.3 6000 176.55.25.25 5995 extendable
ip route 0.0.0.0 0.0.0.0 192.168.2.1 track 1
ip route 0.0.0.0 0.0.0.0 176.55.25.26 254
ip sla 1
icmp-echo 95.110.100.100
threshold 2
timeout 4000
frequency 10
ip sla schedule 1 life forever start-time now
access-list 5 permit any
route-map backup permit 10
match ip address 5
match interface GigabitEthernet0/0
route-map primary permit 10
match ip address 5
match interface GigabitEthernet0/1
I would appreciate if somebody could help me to find what is wrong in this configuration.
Thanks in advance
16 Replies 16
marianares0001
Level 2
Level 2
I am still trying to solve this problem. I have tried also with this "nat inside source static" configuration:
ip nat inside source static udp 192.168.1.3 6000 176.55.25.25 6995 route-map GigabitEthernet0/0
ip nat inside source static udp 192.168.1.3 6000 192.168.2.2 6995 route-map GigabitEthernet0/1
But with no success,
i would appreciate if somebody could help me with this.
Thanks in advance
I would appreciate if somebody could help me with this problem. It's very important.
Thanks in advance
What isn't working? Can you post your access-list 5?
HTH, John *** Please rate all useful posts ***
I cannot open the port to remotely connect to the equipment with IP:192.168.1.3 through port:6000 With this command:
Access-list 5 is:
Thanks!
You'll want to change your acl to permit only the subnet you want to translate:
access-list 5 permit 192.168.1.0 0.0.0.255
I didn't see the access-list above, but I see it now
Thanks a lot,
I am changing the configuration remotely, so, do you think that I will lose the ssh connection if I change one access list to the other one?
Thanks!
You may....SSH into the public side and you should be able to change it.
I have changed the access-list, but I still can't connect to the IP and Port. The current configuration is:
description backup
ip nat outside
load-interval 30
duplex auto
speed auto
description primary
ip nat outside
load-interval 30
duplex auto
speed auto
interface Vlan1
ip nat inside
load-interval 30
ip sla 1
threshold 2
timeout 4000
frequency 10
match ip address 5
match ip address 5
can you try adding this:
ip nat inside source static udp 192.168.1.3 6000 192.168.2.2 5995 extendable
Regards.
Alain
Thanks a lot for your help, but that also doesn't work...
What direction are you trying? From the outside or in? Can you do a "debug ip nat", try to get into the port, and then post the results from the debug? Are you 100% certain that this port is udp and whatever application that uses it is running?
Can you get into port 6000 from a local host?
I try to connect to IP: 176.55.25.25 through port 5995, to connect to a equipment inside the router with IP: 192.168.1.3 and port: 6000.
The first thing I though was that there was a problem with the program to connect, but I have also tried opening port 23 and trying telnet, but also doesn't work.
ip nat inside source static tcp 192.168.1.3 23 176.55.25.25 5995
From the router I can telnet the IP 192.168.1.3 (from inside the network)
I cannot do a "debug" because with the last command I lost the connection ssh to the router...
I will try later, or I will ask to reload the router.
If you can telnet to the host from the router, then your static translation should work. What is the default gateway on the host?
Configuration related the NAT looks good, I would say there is something else Stoping that traffic.
So the first thing I will suggest is to do a capture
ip access-list e Test
permit ip tcp any host 176.55.25.25 eq 5995
permit ip udp  any host 176.55.25.25 eq 5995
permit ip any any
ip access-group TEST in
Then try to connect to that server.
Afterwards do a show access-list TEST... We will need to see if there is  hit on that ACL. If not well the traffic is not reaching the router.
Julio
Do rate all the helpful posts
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
