Problem with IS-IS and OSPFv3 inter-domain
ouedernik01
I'm having some problems with linking 3 domains. One is IS-IS and the others are OSPFv3. Everything is in IPv6.
Everything works fine except the inter-domain.
I guess that the problem is the redistribute, but I can't figure out why and what can I do to solve it.
Here is the configuration of the ASBR_Backbone_2, the other one is almost the same, there are just the adresses that change:
ipv6 unicast-routing
username R_Area3_R1 password 0 Cisco12345
interface FastEthernet0/0
no ip address
duplex auto
speed auto
ipv6 address 2002:AAAA:BBBB:0:4000::1/68
ipv6 enable
ipv6 ospf 100 area 0
interface Serial0/3/0
no ip address
encapsulation ppp
ipv6 address 2002:AAAA:BBBB:0:D000::7/127
ipv6 enable
ipv6 router isis
ppp authentication chap
router isis
net 49.0006.1921.6800.6001.00
is-type level-2-only
redistribute ospf 100 level-1-2
ip forward-protocol nd
ipv6 router ospf 100
router-id 122.0.12.1
log-adjacency-changes
redistribute isis level-1-2
end
Edit: isis database on R_Area1_r2 and ipv6 route of ASBR_Backbone_2
IS-IS database Verbose :
IS-IS Level-2 Link State Database:
LSPID LSP Seq Num LSP Checksum LSP Holdtime ATT/P/OL
R_Area1_R1.00-00 0x000002DA 0xCC56 747 0/0/0
Area Address: 49.0001
NLPID: 0x8E
Router ID: 129.1.142.0
Hostname: R_Area1_R1
Metric: 10 IS R_Area2_R1.02
Metric: 10 IS R_Area1_R2.02
Metric: 10 IS R_Area1_R3.01
IPv6 Address: 2002:AAAA:BBBB:0:D000::1
Metric: 10 IPv6 2002:AAAA:BBBB:0:C000::/70
Metric: 10 IPv6 2002:AAAA:BBBB:0:D000::/127
Metric: 10 IPv6 2002:AAAA:BBBB:0:C400::/70
Metric: 20 IPv6 2002:AAAA:BBBB:0:D000::4/127
Metric: 20 IPv6 2002:AAAA:BBBB:0:D000::2/127
R_Area1_R2.00-00 0x000002E0 0x62F8 1036 0/0/0
NLPID: 0x8E
Hostname: R_Area1_R2
IPv6 Address: 2002:AAAA:BBBB:0:D000::2
Metric: 10 IS R_Area3_R1.01
Metric: 10 IPv6 2002:AAAA:BBBB:0:D000::2/127
Metric: 20 IPv6 2002:AAAA:BBBB:0:C000::/70
Metric: 20 IPv6 2002:AAAA:BBBB:0:D000::/127
Metric: 30 IPv6 2002:AAAA:BBBB:0:D000::4/127
R_Area1_R2.02-00 0x00000020 0x8A17 961 0/0/0
Metric: 0 IS R_Area1_R2.00
Metric: 0 IS R_Area1_R1.00
R_Area1_R3.00-00 0x000002CD 0x22CB 454 0/0/0
NLPID: 0x8E
Hostname: R_Area1_R3
Metric: 10 IS R_Area1_R3.03
IPv6 Address: 2002:AAAA:BBBB:0:D000::4
Metric: 10 IPv6 2002:AAAA:BBBB:0:D000::4/127
Metric: 30 IPv6 2002:AAAA:BBBB:0:D000::2/127
Metric: 20 IPv6 2002:AAAA:BBBB:0:C400::/70
R_Area1_R3.01-00 0x0000001F 0x9908 1162 0/0/0
Metric: 0 IS R_Area1_R3.00
R_Area1_R3.03-00 0x000002A4 0xFEE8 851 0/0/0
Metric: 0 IS R_Area4_R1.00
R_Area2_R1.00-00 0x000002BA 0x17DD 493 0/0/0
Area Address: 49.0002
NLPID: 0x8E
Hostname: R_Area2_R1
Metric: 10 IS R_Area2_R1.01
Metric: 10 IPv6 2002:AAAA:BBBB:0:CC00::/70
Metric: 20 IPv6 2002:AAAA:BBBB:0:D000::A/127
R_Area2_R1.01-00 0x000002A7 0x5198 977 0/0/0
Metric: 0 IS R_Area2_R1.00
Metric: 0 IS R_Area2_R2.00
R_Area2_R1.02-00 0x000002A4 0xB547 1145 0/0/0
R_Area2_R2.00-00 0x000002C5 0x2A19 799 0/0/0
NLPID: 0x8E
Hostname: R_Area2_R2
Metric: 10 IS R_Area2_R2.02
IPv6 Address: 2002:AAAA:BBBB:0:D000::B
Metric: 10 IPv6 2002:AAAA:BBBB:0:D000::A/127
R_Area2_R2.02-00 0x000000DA 0x5B2B 1108 0/0/0
Metric: 0 IS ASBR_Backbone_.00
R_Area3_R1.00-00 0x000002C0 0x30E6 1179 0/0/0
Area Address: 49.0003
NLPID: 0x8E
Hostname: R_Area3_R1
Metric: 10 IS ASBR_Backbone_.00
IPv6 Address: 2002:AAAA:BBBB:0:D000::6
Metric: 10 IPv6 2002:AAAA:BBBB:0:D000::6/127
R_Area3_R1.01-00 0x000002A3 0x18C5 930 0/0/0
Metric: 0 IS R_Area3_R1.00
R_Area4_R1.00-00 0x000002C3 0xC641 509 0/0/0
Area Address: 49.0004
NLPID: 0x8E
Hostname: R_Area4_R1
IPv6 Address: 2002:AAAA:BBBB:0:D000::8
Metric: 10 IPv6 2002:AAAA:BBBB:0:D000::8/127
ASBR_Backbone_.00-00 0x000000F3 0x81E8 1110 0/0/0
Area Address: 49.0005
NLPID: 0x8E
Hostname: ASBR_Backbone_1
IPv6 Address: 2002:AAAA:BBBB:0:D000::A
ASBR_Backbone_.00-00* 0x00000037 0x7CC4 1177 0/0/0
Area Address: 49.0006
NLPID: 0xCC 0x8E
Hostname: ASBR_Backbone_2
IPv6 Address: 2002:AAAA:BBBB:0:D000::7
Metric: 10 IS R_Area3_R1.00
ASBR_Backbone_.00-00 0x0000011C 0x58DB 478 0/0/0
Area Address: 49.0007
NLPID: 0xCC 0x8E
Hostname: ASBR_Backbone_3
IPv6 Address: 2002:AAAA:BBBB:0:D000::9
Metric: 10 IPv6 2002:AAAA:BBBB:0:D000::9/127
Metric: 10 IS R_Area4_R1.00
IPv6 route :
IPv6 Routing Table - 14 entries
Codes: C - Connected, L - Local, S - Static, R - RIP, B - BGP
U - Per-user Static route
I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea, IS - ISIS summary
O - OSPF intra, OI - OSPF inter, OE1 - OSPF ext 1, OE2 - OSPF ext 2
ON1 - OSPF NSSA ext 1, ON2 - OSPF NSSA ext 2
C 2002:AAAA:BBBB:0:4000::/68 [0/0]
via ::, FastEthernet0/0
L 2002:AAAA:BBBB:0:4000::1/128 [0/0]
I2 2002:AAAA:BBBB:0:C000::/70 [115/40]
via FE80::7ABA:F9FF:FECE:4BE0, Serial0/3/0
I2 2002:AAAA:BBBB:0:C400::/70 [115/30]
I2 2002:AAAA:BBBB:0:CC00::/70 [115/50]
I2 2002:AAAA:BBBB:0:D000::/127 [115/40]
I2 2002:AAAA:BBBB:0:D000::2/127 [115/20]
I2 2002:AAAA:BBBB:0:D000::4/127 [115/50]
C 2002:AAAA:BBBB:0:D000::6/127 [0/0]
via ::, Serial0/3/0
L 2002:AAAA:BBBB:0:D000::7/128 [0/0]
via ::, Serial0/3/0
I2 2002:AAAA:BBBB:0:D000::8/127 [115/60]
I2 2002:AAAA:BBBB:0:D000::A/127 [115/60]
L FE80::/10 [0/0]
via ::, Null0
L FF00::/8 [0/0]
via ::, Null0
5 Replies 5
Julio E. Moisa
Try configuring the following commands for IS-IS:
metric-style wide [transition] [level-1 | level-2 | level-1-2
 multi-topology
Note: metric-style wide should be changed for all the routers running Intermediate System Intermediate System.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hey thanks for the answer, I appreciate
Unfortunately it did not solve the problem. Why does generate and accept only new-style TLVs would work?
Try to include:
router isis
redistribute ospf 100 level-1-2 include-connected
redistribute isis level-1-2  include-connected
If your IS-IS domain is level 2 on the backbone it should be redistributed isis level-2 only, level-1-2 is the default level.
Thanks again,
It still doesn't work. I also tried with a default route and I analysed a ping from S13 to S6. The packet is sent but it doesnt get I reply. I'm pretty sure it's because it doesn't know where to reply since it doesn't know the what is inside the OSPFv3 domaine.
I'll edit the post to add the isis on R_Area1_R2 and the ipv6 route of the ASBR_Backbone_2
Please let me lab it in order to find the problem.
