Problem with layer 3 between a Cisco Catalyst 3750G and Cisco 892F
Hello.
I have a Cisco Catalyst 3750G with ipservices that handle all routing for me in the datacenter out to location. We got some own dark fiber. When we take the router and put it on the ISP modem it works. When I put it on the black fiber it dosent work.
Can anyone help me with this?
From the router I can see that I have som unkown protocol drops:
11444 unknown protocol drops
I can se the router form CDP, but ping does not work.
You can se the drawing below.
Configuration of Cisco 3750G(Core Switch):
Current configuration : 19646 bytes
! Last configuration change at 11:22:25 gmt Tue Nov 5 2013 by tspe2
! NVRAM config last updated at 10:43:49 gmt Tue Nov 5 2013 by tspe2
version 12.2
no service pad
service timestamps debug uptime
service timestamps log datetime localtime show-timezone year
service password-encryption
hostname NOOTKDRSW01
boot-start-marker
boot-end-marker
logging console notifications
logging monitor informational
enable secret 5 xxxxxxxxxxxxxxxxxxxxxx
enable password 7 xxxxxxxxxxxxxxxxxxxx
username xxx privilege 15 password 7 xxxxxxxxxxxxxxx
aaa new-model
aaa authentication login default group radius local
aaa authorization exec default group radius local
aaa session-id common
clock timezone gmt 2
switch 1 provision ws-c3750g-24ts-1u
switch 2 provision ws-c3750g-12s
switch 3 provision ws-c3750g-12s
switch 4 provision ws-c3750g-24ts-1u
system mtu routing 1500
authentication mac-move permit
ip subnet-zero
ip routing
ip domain-name xxxxxxxxxxxxxxxxxxx
ip name-server 32.53.34.2
ip name-server 10.23.50.12
no ip dhcp use vrf connected
ip dhcp excluded-address vrf ADMIN 10.22.64.1 10.22.64.110
ip dhcp pool ADMIN
   vrf ADMIN
   network 10.22.64.0 255.255.255.0
   default-router 10.22.64.1
   domain-name ostre-toten.kommune.no
   dns-server 10.23.50.12 32.53.34.2
ip vrf ADMIN
rd 65500:1
ip vrf DRIFT
rd 65000:4
ip vrf ELEV
rd 65500:2
ip vrf IPT
rd 65500:3
ip vrf SIKKER
rd 65500:5
ip vrf SIKKERM
rd 65500:6
no ip igmp snooping vlan 52
port-channel load-balance src-dst-ip
archive
path ftp://x.x.x.x/NOOTKDRSW01/NOOTKDRSW01
write-memory
spanning-tree mode rapid-pvst
spanning-tree etherchannel guard misconfig
spanning-tree vlan 1-11,22-23,25,31,34-35,40-41,50,52,60,66,70 priority 24576
spanning-tree vlan 71-72,80-81,90,100-101,103,106,150,199,201 priority 24576
spanning-tree vlan 298-299,301-305,352,500-503,511-513,600-607 priority 24576
spanning-tree vlan 900-901,910,920 priority 24576
vlan internal allocation policy ascending
ip ftp username xxxxxx
ip ftp password 7 xxxxxx
ip ssh version 2
interface Port-channel1
description Link NOOTKDRSW02
switchport mode trunk
interface Port-channel2
description Port-channel - WLC5508
switchport nonegotiate
interface GigabitEthernet1/0/1
description ASA01 ETH0 - Ytre Brannmur
switchport trunk allowed vlan 5,22,352,400,901
speed 1000
duplex full
spanning-tree portfast
interface GigabitEthernet1/0/2
description ASA01 ETH1 - Ytre Brannmur
switchport trunk allowed vlan 1,7,10,23,31,35,50,500,503,511,999
speed 1000
duplex full
interface GigabitEthernet1/0/3
description Workspace host
switchport access vlan 35
switchport mode access
interface GigabitEthernet1/0/4
description vWorkspace Host Trunk
spanning-tree portfast trunk
interface GigabitEthernet1/0/5
description Link-Fjellhall-Internett
switchport trunk allowed vlan 352
speed 100
duplex full
no cdp enable
spanning-tree bpdufilter enable
interface GigabitEthernet1/0/6
description Link-Juniper-Driftsnett
switchport access vlan 2
switchport trunk native vlan 2
switchport trunk allowed vlan 2,8,52,80,512,513,601,606,920
interface GigabitEthernet1/0/7
switchport access vlan 606
interface GigabitEthernet1/0/8
description IPTEL-IPSWITCH01-P0/7
switchport access vlan 72
interface GigabitEthernet1/0/9
description link nootksi-gw01
switchport access vlan 303
speed 100
duplex full
interface GigabitEthernet1/0/10
description Link NHN Router - Indre Brannmur
switchport access vlan 607
interface GigabitEthernet1/0/11
description Link - Juniper Eidsiva - Elev
switchport access vlan 602
interface GigabitEthernet1/0/12
description Link - Juniper Eidsiva - Adminnett
switchport access vlan 601
interface GigabitEthernet1/0/13
description Link NOOTKDRSW03
switchport trunk native vlan 35
switchport trunk allowed vlan 35,52
interface GigabitEthernet1/0/14
description Link-Internett ElevBrannmur
switchport access vlan 352
switchport trunk native vlan 199
interface GigabitEthernet1/0/15
switchport access vlan 10
interface GigabitEthernet1/0/16
description Link-JuniperEidsiva-Elev
switchport trunk native vlan 4
switchport trunk allowed vlan 4,602
interface GigabitEthernet1/0/17
description Elev-server2 Elebrannmur
switchport trunk allowed vlan 201
interface GigabitEthernet1/0/18
shutdown
interface GigabitEthernet1/0/19
description Link Region - RegionBrannmur
switchport access vlan 31
interface GigabitEthernet1/0/20
description WLC
interface GigabitEthernet1/0/21
description WLC-Service Port
interface GigabitEthernet1/0/22
description LInk - Juniper Eidsiva - SikkerSone
switchport access vlan 603
interface GigabitEthernet1/0/23
description Test
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
description Link Bibliotek SW01
interface GigabitEthernet1/0/27
description Link Bibliotek Switch 2
interface GigabitEthernet1/0/28
channel-group 1 mode active
interface GigabitEthernet2/0/1
description Helsestasjon
interface GigabitEthernet2/0/2
description Link Kantswitch - NOOKKSSW01
interface GigabitEthernet2/0/3
description Link Samfunn-NOOTK2ASW01
interface GigabitEthernet2/0/4
description Link VillaValheim
interface GigabitEthernet2/0/5
description Link NOOTK-SW02 P46
interface GigabitEthernet2/0/6
description Link-2 WLC5508
channel-group 2 mode on
interface GigabitEthernet2/0/7
interface GigabitEthernet2/0/8
interface GigabitEthernet2/0/9
description Link NOOTKDRSW03 - Port GI2/0/28
interface GigabitEthernet2/0/10
description Link mot NOOTKNAVSW01
switchport trunk allowed vlan 1,35,40
interface GigabitEthernet2/0/11
description NOOTKNAVSW02
interface GigabitEthernet2/0/12
description Link NOOTK1ASW01
interface GigabitEthernet3/0/1
description Link NOOTKKSSW02
interface GigabitEthernet3/0/2
description Link Barnevern - NOOTK1DSW01
interface GigabitEthernet3/0/3
interface GigabitEthernet3/0/4
interface GigabitEthernet3/0/5
interface GigabitEthernet3/0/6
interface GigabitEthernet3/0/7
interface GigabitEthernet3/0/8
interface GigabitEthernet3/0/9
description Link Brannstasjon
switchport access vlan 301
interface GigabitEthernet3/0/10
description Link til 6500
interface GigabitEthernet3/0/11
description link Len u Skole
switchport trunk allowed vlan 299,301,302,304
shutdown
interface GigabitEthernet3/0/12
description NOOTK-WLC02 - Management
interface GigabitEthernet4/0/1
description UPS
interface GigabitEthernet4/0/2
description Punkt 1 Bibliotek
interface GigabitEthernet4/0/3
description Punkt 3 Bibliotek
interface GigabitEthernet4/0/4
description Punkt 5 Bibliotek
interface GigabitEthernet4/0/5
description Punkt 7 Bibliotek
interface GigabitEthernet4/0/6
description Punkt 9 Bibliotek
interface GigabitEthernet4/0/7
description Punkt 11 Bibliotek
interface GigabitEthernet4/0/8
description Punkt 17 Bibliotek
interface GigabitEthernet4/0/9
description Punkt 27 Bibliotek
interface GigabitEthernet4/0/10
description NOOTKWLC02 - Tradlos
interface GigabitEthernet4/0/11
interface GigabitEthernet4/0/12
description Link-region - Regionsbrannmur2
interface GigabitEthernet4/0/13
description Link Indre brannmur - Ytrebrannmur
speed 1000
duplex full
interface GigabitEthernet4/0/14
description Indre Brannmur - Sikker Sone
switchport access vlan 40
speed 1000
duplex full
interface GigabitEthernet4/0/15
description Indre Brannmur - Gi0/2
switchport trunk native vlan 9
switchport trunk allowed vlan 9,41,60,70,71,100,101,603,605
speed 1000
duplex full
interface GigabitEthernet4/0/16
description Indre Brannmur - Kursnett
switchport trunk native vlan 910
switchport trunk allowed vlan 9,41,60,70,71,100,101,150,298,603,605,607,999
interface GigabitEthernet4/0/17
description NHN - Router
switchport trunk allowed vlan 103,106
interface GigabitEthernet4/0/18
description Link-Elev-Eidsiva
switchport access vlan 106
interface GigabitEthernet4/0/19
description NAV-OTK
switchport access vlan 999
speed 100
duplex full
no mdix auto
interface GigabitEthernet4/0/20
shutdown
interface GigabitEthernet4/0/21
description Link Eidsiva SWitch Admin
spanning-tree bpduguard disable
interface GigabitEthernet4/0/22
switchport trunk allowed vlan 305
interface GigabitEthernet4/0/23
description Link Eidsiva-Elevnett
switchport access vlan 302
interface GigabitEthernet4/0/24
switchport access vlan 304
interface GigabitEthernet4/0/25
interface GigabitEthernet4/0/26
interface GigabitEthernet4/0/27
interface GigabitEthernet4/0/28
interface Vlan1
no ip address
shutdown
interface Vlan2
ip vrf forwarding ADMIN
ip address 10.22.30.1 255.255.254.0
interface Vlan4
ip vrf forwarding ELEV
ip address 10.22.254.1 255.255.254.0
interface Vlan22
ip vrf forwarding DRIFT
ip address 10.22.127.2 255.255.255.0
interface Vlan35
ip address 10.22.35.100 255.255.255.0
no ip mroute-cache
interface Vlan52
no ip address
interface Vlan72
ip vrf forwarding IPT
ip address 10.22.49.1 255.255.255.0
interface Vlan298
ip vrf forwarding SIKKERM
ip address 10.23.127.2 255.255.255.0
no ip proxy-arp
interface Vlan299
description SikkerSOne Midlertidig
ip address 10.23.128.1 255.255.255.0
no ip proxy-arp
interface Vlan301
ip address 10.22.64.1 255.255.255.0
no ip proxy-arp
interface Vlan302
description Eidsiva-Elev-Link
ip address 10.22.192.1 255.255.255.0
no ip proxy-arp
interface Vlan303
description Sikker Sone - Eidsiva
ip address 10.22.128.1 255.255.255.0
interface Vlan304
description Eidsiva-IPT
ip address 10.22.50.1 255.255.255.0
interface Vlan305
ip address 10.22.126.1 255.255.255.0
interface Vlan605
ip address 10.22.63.2 255.255.255.0
router eigrp 10
address-family ipv4 vrf ADMIN autonomous-system 301
  redistribute ospf 2 vrf ADMIN metric 10000 1 1 1 1500
  redistribute ospf 2
  network 10.22.30.1 0.0.0.0
  network 10.22.64.0 0.0.0.255
  passive-interface default
  no passive-interface Vlan301
exit-address-family
router eigrp 303
router ospf 2 vrf ADMIN
log-adjacency-changes
network 10.22.30.1 0.0.0.0 area 1
default-information originate
router ospf 1
ip default-gateway 10.22.35.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.22.35.1
ip route vrf ADMIN 0.0.0.0 0.0.0.0 10.22.30.2
ip route vrf ADMIN 10.22.66.0 255.255.255.0 10.22.64.3
ip route vrf ADMIN 10.22.68.0 255.255.255.0 10.22.64.4
ip route vrf ADMIN 10.22.79.0 255.255.255.0 10.22.64.16
ip route vrf ADMIN 10.22.79.100 255.255.255.255 10.22.64.64
ip route vrf ADMIN 10.22.79.106 255.255.255.255 10.22.64.64
ip route vrf ADMIN 10.22.80.0 255.255.255.0 10.22.64.17
ip route vrf ADMIN 10.22.81.0 255.255.255.0 10.22.64.252
ip route vrf ADMIN 10.22.82.0 255.255.255.0 10.22.64.19
ip route vrf ADMIN 10.22.83.0 255.255.255.0 10.22.64.20
ip route vrf ADMIN 10.22.84.0 255.255.255.0 10.22.64.21
ip route vrf ADMIN 10.22.86.0 255.255.255.0 10.22.64.86
ip route vrf ADMIN 10.22.88.0 255.255.255.0 10.22.64.88
ip route vrf ADMIN 10.22.90.0 255.255.255.0 10.22.64.90
ip route vrf ADMIN 10.22.91.0 255.255.255.0 10.22.64.91
ip route vrf ADMIN 10.22.92.0 255.255.255.0 10.22.64.92
ip route vrf ADMIN 10.22.93.0 255.255.255.0 10.22.64.22
ip route vrf DRIFT 0.0.0.0 0.0.0.0 10.22.127.1
ip route vrf DRIFT 10.22.122.0 255.255.255.0 10.22.126.5
ip route vrf DRIFT 10.22.123.0 255.255.255.0 10.22.126.4
ip route vrf DRIFT 10.22.124.0 255.255.255.0 10.22.126.3
ip route vrf DRIFT 10.22.125.0 255.255.255.0 10.22.126.2
ip route vrf DRIFT 10.22.126.0 255.255.255.0 10.22.126.6
ip route vrf IPT 0.0.0.0 0.0.0.0 10.22.49.4
ip route vrf IPT 10.22.40.0 255.255.255.0 10.22.50.64
ip route vrf IPT 10.22.41.0 255.255.255.0 10.22.50.64
ip route vrf IPT 10.22.42.0 255.255.255.0 10.22.50.254
ip route vrf IPT 10.22.43.0 255.255.255.0 10.22.50.64
ip route vrf IPT 10.22.44.0 255.255.255.0 10.22.50.64
ip route vrf IPT 10.22.45.0 255.255.255.0 10.22.50.204
ip route vrf IPT 10.22.46.0 255.255.255.0 10.22.50.4
ip route vrf IPT 10.22.47.0 255.255.255.0 10.22.50.3
ip route vrf IPT 10.22.48.0 255.255.255.0 10.22.50.64
ip route vrf IPT 10.72.8.0 255.255.255.0 10.22.50.64
ip route vrf IPT 10.72.9.0 255.255.255.0 10.22.50.64
ip route vrf IPT 10.72.24.0 255.255.255.0 10.22.50.24
ip route vrf SIKKER 0.0.0.0 0.0.0.0 10.22.63.1
ip route vrf SIKKER 10.22.129.0 255.255.255.0 10.22.128.90
ip route vrf SIKKER 10.22.130.0 255.255.255.0 10.22.128.3
ip route vrf SIKKER 10.22.131.0 255.255.255.0 10.22.128.4
ip route vrf SIKKER 10.22.132.0 255.255.255.0 10.22.128.5
ip route vrf SIKKER 10.22.133.0 255.255.255.0 10.22.128.96
ip route vrf SIKKER 10.22.134.0 255.255.255.0 10.22.128.7
ip route vrf SIKKER 10.22.135.0 255.255.255.0 10.22.128.31
ip route vrf SIKKER 10.22.137.0 255.255.255.0 10.22.128.79
ip route vrf SIKKER 10.22.138.0 255.255.255.0 10.22.128.11
ip route vrf SIKKER 10.22.139.0 255.255.255.0 10.22.128.154
ip route vrf SIKKER 10.22.141.0 255.255.255.0 10.22.128.14
ip route vrf SIKKER 10.22.142.0 255.255.255.0 10.22.128.15
ip route vrf SIKKER 10.22.143.0 255.255.255.0 10.22.128.14
ip route vrf SIKKER 10.22.144.0 255.255.255.0 10.22.128.35
ip route vrf SIKKER 10.22.145.0 255.255.255.0 10.22.128.22
ip route vrf SIKKER 10.22.149.0 255.255.255.0 10.22.128.22
ip route vrf SIKKER 10.22.150.0 255.255.255.0 10.22.128.23
ip route vrf SIKKER 10.22.151.0 255.255.255.0 10.22.128.24
ip route vrf SIKKER 10.22.152.0 255.255.255.0 10.22.128.25
ip route vrf SIKKER 10.22.154.0 255.255.255.0 10.22.128.110
ip route vrf SIKKER 10.22.159.0 255.255.255.0 10.22.128.153
ip route vrf SIKKER 10.22.191.0 255.255.255.0 10.22.128.10
ip route vrf SIKKERM 0.0.0.0 0.0.0.0 10.23.127.1
ip route vrf SIKKERM 10.22.139.0 255.255.255.0 10.23.128.4
ip route vrf ELEV 0.0.0.0 0.0.0.0 10.22.254.2
ip route vrf ELEV 10.22.194.0 255.255.255.0 10.22.192.3
ip route vrf ELEV 10.22.196.0 255.255.255.0 10.22.192.4
no ip http server
no ip http secure-server
ip sla enable reaction-alerts
logging history debugging
logging trap warnings
logging facility local6
logging source-interface Vlan35
logging xxxxx
snmp-server community public RO
snmp-server location Serverrom - Nettverksskap
snmp-server contact IKT-Avdelingen
snmp-server enable traps license
radius-server host xxxxxx auth-port 1812 acct-port 1813 key 7 xxxxx
line con 0
logging synchronous
line vty 0 4
logging synchronous
length 0
transport input ssh
line vty 5 15
monitor session 1 source interface Gi1/0/7
monitor session 2 source interface Gi1/0/3
monitor session 2 source interface Gi4/0/21
monitor session 2 destination interface Gi1/0/23
ntp clock-period 36028799
ntp server 32.53.34.2
ntp server 129.240.2.6
end
It can see the router by CDP.
Device ID: NOOTK-GW15.ostre-toten.kommune.no
Entry address(es):
  IP address: 10.22.64.15
Platform: Cisco 892F,  Capabilities: Router Switch IGMP
Interface: GigabitEthernet3/0/9,  Port ID (outgoing port): GigabitEthernet0
Holdtime : 131 sec
Version :
Cisco IOS Software, C890 Software (C890-UNIVERSALK9-M), Version 15.1(4)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 21-Mar-12 01:40 by prod_rel_team
advertisement version: 2
VTP Management Domain: ''
Duplex: full
Management address(es):
port statistics on the Switch
GigabitEthernet3/0/9 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is d4a0.2a22.a509 (bia d4a0.2a22.a509)
  Description: Link Brannstasjon
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not set
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseLX SFP
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:31, output 00:00:31, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute output rate 1000 bits/sec, 1 packets/sec
     37653 packets input, 14203995 bytes, 0 no buffer
     Received 37253 broadcasts (37133 multicasts)
     0 watchdog, 37133 multicast, 0 pause input
     12905940 packets output, 1431276186 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
Cisco 892F Configuration:
Current configuration : 1704 bytes
! Last configuration change at 11:40:10 UTC Thu Nov 7 2013
! NVRAM config last updated at 13:07:38 UTC Thu Oct 31 2013
version 15.1
service config
hostname NOOTK-GW15
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip vrf ADMIN
rd 65515:1
ip cef
no ipv6 cef
license udi pid CISCO892F-K9 sn FCZ1652C438
username Admin privilege 15 password 0 3BEIN2PP
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
no ip address
media-type sfp
interface GigabitEthernet0.301
description InternSone
encapsulation dot1Q 301
ip address 10.22.64.15 255.255.255.0
interface Vlan1
no ip address
ip forward-protocol nd
no ip http server
access-list 1 permit 10.22.64.0 0.0.0.255 log
control-plane
mgcp profile default
line con 0
line aux 0
line vty 0 4
login
transport input all
end
CDP from the router
Device ID: NOOTKDRSW01.ostre-toten.kommune.no
Entry address(es):
Platform: cisco WS-C3750G-24TS-1U,  Capabilities: Router Switch IGMP
Interface: GigabitEthernet0,  Port ID (outgoing port): GigabitEthernet3/0/9
Holdtime : 140 sec
Version :
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(53)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Sun 13-Dec-09 16:25 by prod_rel_team
Protocol Hello:  OUI=0x00000C, Protocol ID=0x0112; payload len=27, value=00000000FFFFFFFF010221FF000000000000F4ACC187E800FF0000
VTP Management Domain: 'OTK'
Native VLAN: 301
Duplex: full
Port statistics from the router:
GigabitEthernet0 is up, line protocol is up
  Hardware is PQII_PRO_UEC, address is 4403.a736.a6ee (bia 4403.a736.a6ee)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
  Full Duplex, 1Gbps, media type is LX
  output flow-control is XON, input flow-control is XON
  Last input 00:00:00, output 00:00:25, output hang never
     1100781 packets input, 91039560 bytes, 0 no buffer
     Received 1099829 broadcasts (0 IP multicasts)
     0 watchdog, 0 multicast, 0 pause input
     11657 packets output, 4306491 bytes, 0 underruns
     0 output errors, 0 collisions, 7 interface resets
     0 lost carrier, 0 no carrier, 0 pause output
0 Replies 0
