Problem with OSPF-process in 6807 vs 6500
Nevyn Bergstrom
After having implemented a command to free up some of the "locked" tags and the subsequent reboot of our 6807 and 6880 we're having problems with ospf between the 6807 and our 6500. Between the rebooted switches we're running BGP so are not encountering this problem. The 6500 is successfully running an OSPF link against another switch.
Anyone heard of a bug causing this? Any solution?
We're running 15.2(1)sy2 s2t-54-adventerprisek9-m. All switches involved are VSS-pairs
Initially we had problems with the OSPF negotiations but we changed the links to point-to-point (same as on the working link from the 6500).
what OSPF command did you use initially ? And what is the problem you are experiencing now ?
