Problem with radius authentication on catalyst 2960
Johan Boeckx
Hi all,
I have a problem with radius authentication on catalyst 2960 with freeradius as radius-server. The Catalyst is behind a HP5412zl layer3-switch. The rest of the network are hp-layer2 switches, which do radius authentication to the same radius server. The ios on the catalyst is c2960-lanbasek9-mz.150-1.SE3.
Appaerntly there are no requests made to the radius-server, since I dont see any requests coming in. Port 0/7 is voice port with laptop behind , /port 0/8 access-port with laptop directly connected.
config :
aaa new-model
aaa authentication dot1x default group radius
dot1x system-auth-control
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
switchport access vlan 3
switchport mode access
switchport voice vlan 16
authentication port-control auto
mls qos trust device cisco-phone
interface FastEthernet0/8
spanning-tree portfast
interface GigabitEthernet0/1
switchport trunk allowed vlan 1-3
switchport mode trunk
switchport nonegotiate
interface Vlan2
ip address 10.104.253.5 255.255.255.0
ip default-gateway 10.104.253.1
radius server radius
address ipv4 10.104.254.175 auth-port 1812 acct-port 1813
key 7 045802150C2E
From the logs : (debug authentication, debug dotx11 after enabling authentication port-control auto on fa 0/8
*Mar  1 03:19:09.588: AUTH-EVENT (Fa0/8) Removed the default method from the interface
*Mar  1 03:19:09.588: AUTH-EVENT (Fa0/8) Disabling dot1x in switch shim
*Mar  1 03:19:09.588: AUTH-EVENT (Fa0/8)  host access set to 0 on FastEthernet0/8
*Mar  1 03:19:09.588: AUTH-EVENT (Fa0/8) Client delete *ALL* from platform (2)
*Mar  1 03:19:09.588: AUTH-EVENT (Fa0/8) Ignoring delete *ALL* - previous pending
*Mar  1 03:19:09.588: AUTH-EVENT (Fa0/8) Queued subblock to be destroyed
*Mar  1 03:19:09.588: AUTH-EVENT (Fa0/8) Created Auth Manager SWSB (0x01EB4058)
*Mar  1 03:19:09.588: AUTH-EVENT (Fa0/8) Set port control (3->2)
*Mar  1 03:19:09.588: AUTH-EVENT (Fa0/8) Enabling dot1x in switch shim
*Mar  1 03:19:09.588: AUTH-EVENT (Fa0/8)  host access set to 1 on FastEthernet0/8
*Mar  1 03:19:09.596: AUTH-EVENT (Fa0/8) Queued START
*Mar  1 03:19:09.596: AUTH-EVENT (Fa0/8) Received internal event DELETE ALL
*Mar  1 03:19:09.596: AUTH-EVENT (Fa0/8) Stopped 'inactivity' timer for client 0026.b99a.8f2f
*Mar  1 03:19:09.596: AUTH-EVENT (Fa0/8) Signalling "pre" delete for client 0026.b99a.8f2f
*Mar  1 03:19:09.596: AUTH-EVENT: Enter auth_mgr_idc_client_deleted
*Mar  1 03:19:09.596: AUTH-EVENT: Enter auth_mgr_idc_remove_record
*Mar  1 03:19:09.596: AUTH-SYNC (Fa0/8) Syncing delete for context (0026.b99a.8f2f)
*Mar  1 03:19:09.596: AUTH-EVENT (Fa0/8) Sending DELETE to  (handle 0x7E00000B)
*Mar  1 03:19:09.596: AUTH-EVENT (Fa0/8) Freeing AAA-ID 0x0000001F for 0026.b99a.8f2f
*Mar  1 03:19:09.596: AUTH-EVENT (Fa0/8) Signalling "post" delete for client 0026.b99a.8f2f in domain DATA
*Mar  1 03:19:09.605: AUTH-EVENT (Fa0/8) Authorized client count: 0
*Mar  1 03:19:09.605: AUTH-EVENT (Fa0/8) Setting vlan to 0 on DATA Vlan
*Mar  1 03:19:09.605: AUTH-EVENT (Fa0/8) Unauthorizing interface in shim
*Mar  1 03:19:09.605: AUTH-EVENT (Fa0/8) set host access to ask on FastEthernet0/8
*Mar  1 03:19:09.605: AUTH-EVENT (Fa0/8)  host access set to 1 on FastEthernet0/8
*Mar  1 03:19:09.605: AUTH-EVENT (Fa0/8) Get domain: Unknown MAC: 0026.b99a.8f2f
*Mar  1 03:19:09.605: AUTH-EVENT (Fa0/8) Domain DATA client count: 0
*Mar  1 03:19:09.605: AUTH-EVENT (Fa0/8) Freed Auth Manager context
*Mar  1 03:19:09.605: AUTH-EVENT: Received internal event DELETE SUBBLOCK
*Mar  1 03:19:09.605: AUTH-EVENT: Destroying Auth Manager SWSB (0x038CE600)
*Mar  1 03:19:09.605: AUTH-EVENT: Destroyed Auth Manager SWSB (0x038CE600)
*Mar  1 03:19:09.605: AUTH-EVENT (Fa0/8) Link UP
*Mar  1 03:19:09.605: AUTH-EVENT (Fa0/8) Received internal event START
*Mar  1 03:19:09.613: AUTH-EVENT (Fa0/8) Client delete *ALL* from platform (2)
*Mar  1 03:19:09.613: AUTH-EVENT (Fa0/8) Ignoring delete *ALL* - ctx list empty
*Mar  1 03:19:10.570: AUTH-EVENT: Stopped Auth Manager tick timer
*Mar  1 03:19:10.603: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/8, changed state to down
Anybody who can help me ?
Thanks ,Johan
Peter Koltl
Level 7
Level 7
You mean wired 802.1X ?
radius-server attribute 6 on-for-login-auth
radius-server attribute 8 include-in-access-req
radius-server attribute 25 access-request include
radius-server vsa send accounting
radius-server vsa send authentication
aaa authentication dot1x default group RADGR
aaa authorization network default group RADGR
aaa accounting dot1x default start-stop group RADGR
int F0/x
authentication host-mode multi-domain
dot1x pae authenticator
